  2. Python DLMS Library
Python DLMS Library
By MonBrian, 6 October, 2025
Hello Gurux team and community,
I'm trying to establish a connection with a DLMS meter using the Python bindings for gurux_dlms and gurux_net libraries. I am using a standard HDLC-over-TCP configuration.
My Setup:
Connection Type: TCP/IP
Protocol: HDLC Wrapper (InterfaceType.HDLC)
Host IP: 192.168.1.1 -- ip is not actual ip
Port: 8080
Client Address: 16
Server Address: 1
Libraries: Name: gurux_dlms
Version: 1.0.191
Summary: Gurux DLMS library for Python.
Home-page: https://github.com/gurux/gurux.dlms.python
Author: Gurux Ltd
Author-email: gurux@gurux.fi
License: GPLv2
Location: C:\Users\User\PyCharmMiscProject\.venv\Lib\site-packages
Requires:
Required-by:
I`m not very proficient in programming, any help given to me can mean big to me.
The problem is:
Connected to 192.168.1.1:8080
Error during communication: 'bytearray' object has no attribute 'eop'
Here are my code:
from gurux_dlms import GXDLMSClient, GXReplyData, GXByteBuffer
from gurux_dlms.enums import Authentication, InterfaceType
from gurux_dlms.objects import GXDLMSRegister
from gurux_net import GXNet
HOST = "192.168.1.1"
PORT = 8080
BUFFER_SIZE = 1024 # buffer size for receive
def read_feeder_f21():
client = GXDLMSClient(
useLogicalNameReferencing=True,
clientAddress=16,
serverAddress=1,
forAuthentication=Authentication.NONE,
interfaceType=InterfaceType.HDLC
connection = GXNet("TCP", HOST, PORT)
try:
connection.open()
print(f"Connected to {HOST}:{PORT}")
# Handshake
data = client.snrmRequest()
if data:
connection.send(data)
buffer = bytearray(BUFFER_SIZE)
length = connection.receive(buffer)
reply = bytes(buffer[:length]) # Convert to bytes
reply_buffer = GXByteBuffer(reply)
client.parseUAResponse(reply_buffer)
data = client.aarqRequest()
client.parseAareResponse(reply_buffer)
print("Handshake completed")
# OBIS list
obis_list = {
"L1 Voltage": "1.1.32.7.0.255",
"L2 Voltage": "1.1.52.7.0.255",
"L3 Voltage": "1.1.72.7.0.255",
"L1 Current": "1.1.31.7.0.255",
"L2 Current": "1.1.51.7.0.255",
"L3 Current": "1.1.71.7.0.255",
"Neutral Current": "1.1.91.7.0.255",
"Frequency": "1.1.0.2.0.255",
"Active Power": "1.1.16.7.0.255",
"Power Factor": "1.1.13.7.0.255",
for name, obis in obis_list.items():
try:
obj = GXDLMSRegister(obis)
request_data = client.read(obj, 2)
connection.send(request_data)
# Receive full response (multi-frame support)
response = b""
response += bytes(buffer[:length])
while not client.isComplete(response):
# Parse response
reply_buffer = GXByteBuffer(response)
reply_data = GXReplyData()
client.getData(reply_buffer, reply_data)
if reply_data.value is not None:
print(f"{name}: {reply_data.value}")
else:
print(f"{name}: No value")
except Exception as e:
print(f"Failed to read {name} ({obis}): {e}")
# Release and disconnect
release_data = client.releaseRequest()
if release_data:
connection.send(release_data)
connection.close()
print("Disconnected from F21")
print("Error during communication:", e)
connection.close()
if __name__ == "__main__":
read_feeder_f21()
6 months ago
Hi, I recommend using the…
I recommend using the client example as a base and modifying it to your needs. The reason is not shown in your code.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
