  2. Help To Use Driver
Help to use Driver
By nissi, 3 October, 2025
i used your example driver in python and C# and simulator to, can you tell me more about how to use and how to connect and how to get data form metter or should i use your example code to connect realtime to metter
1 month ago
Hi, You can use the client…
You can use the client example to read all data from your DLMS meters.
You can use the simulator or the real meter.
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • Guidance on using the source codes
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
