  2. How To Prepare Profile General For Writing?
How to prepare Profile General for writing?
By george@n, 31 August, 2025
Gurux DLMS for ANSI C
Using the API's provided, how to prepare the Profile General to look like in your example below? What need to be done before calling cl_write() to prepare array and structures.
https://www.gurux.fi/sites/default/files/issues/Profile%20Generic%20att…
7 months 2 weeks ago
Hi, You want to write…
You want to write capture objects for the profile generic object.
set the capture objects like this:
gxTarget* capture;
//Add clock object.
capture = (gxTarget*)malloc(sizeof(gxTarget));
capture->attributeIndex = 2;
capture->dataIndex = 0;
arr_push(&pg.captureObjects, key_init(&clock1, capture))
Then write attribute #3.
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
