  2. Compiling GuruxDLMSDataCollector With Wirepas
Compiling GuruxDLMSDataCollector with wirepas
By Harshi_554, 8 August, 2025
Gurux DLMS for ANSI C
How to compile GuruxDLMSDataCollector with wirepas ? Im getting compilation error when I tried make command inside wirepas folder.
6 months 1 week ago
Hi, Have you installed…
Have you installed Wirepas SDK? Can you describe what error you are receiving?
Harshi_554
6 months 1 week ago
I have installed wirepas…
I have installed wirepas gateway sdk. Im getting below error
GuruxDLMSDataCollector/wirepas/gurux_dc$ make
makefile:125: *** Too many open files. Stop.
6 months ago
Hi, You need to ask Wirepas…
You need to ask Wirepas what might cause this. This works without problems with our environment.
Harshi_554
6 months ago
Does this source code works…
Does this source code works with all Wirepas SDKs? I used 2.4GHz SDK.
6 months ago
Hi, Yes, it should work. BR,…
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Python GXDLMSTranslator
  • Issue with KWH Value Reading Using Gurux DLMS Library.
  • CEWE Prometer 100
