  2. Need Help On Simulator To Test 1Millions Meter Setup
Need help on simulator to test 1Millions Meter Setup
By sethi.nitin9@g…, 7 August, 2025
I am trying use the simulator to perform load testing on 1 Million meters with same replication as meter does, like secrets, ciphering etc., So I tried to modify crystal.xml but there is little understanding gap I want to fullfill.
Need crystal.xml using which Profile Generics read can be perfomed. I am able to create xml file with HIGH association but can you please provide me xml using which I can read all profile generics with all type of associations.
Below is the file which I have created with refence to the already created one:
[XML removed]
5 months 1 week ago
Hi, You need to add a…
You need to add a profile generic as you added other COSEM objects. Read this as a reference:
https://gurux.fi/Gurux.DLMS.Simulator.Templates
I'll remove the XML because it is not needed.
sethi.nitin9@g…
5 months ago
I am able to create template…
I am able to create template and read profile generics but I added 1 DLMSData meter serial number and it is added into the template but when I tried to read the value for same but it is not coming.
Please verify my templates:
<?xml version="1.0" ?>
<Objects>
<GXDLMSData>
<LN>0.0.42.0.0.255</LN>
<Access>11</Access>
<Value Type="9">47 52 58 33</Value>
</GXDLMSData>
<GXDLMSData>
<LN>0.0.43.1.1.255</LN>
<Access>13</Access>
<Value Type="6">149</Value>
</GXDLMSData>
<GXDLMSAssociationLogicalName>
<LN>0.0.40.0.1.255</LN>
<Version>2</Version>
<Access>13333303333</Access>
<MethodAccess>111111</MethodAccess>
<ObjectList>
<GXDLMSData>
<Access>11</Access>
</GXDLMSData>
<GXDLMSData>
<LN>0.0.96.1.0.255</LN>
<Access>11</Access>
</GXDLMSData>
<GXDLMSClock>
<LN>0.0.1.0.0.255</LN>
<Access>133333333</Access>
<MethodAccess>000000</MethodAccess>
</GXDLMSClock>
<GXDLMSProfileGeneric>
<LN>0.0.94.91.10.255</LN>
<Access>11333333</Access>
<MethodAccess>11</MethodAccess>
</GXDLMSProfileGeneric>
</ObjectList>
<ClientSAP>48</ClientSAP>
<ServerSAP>1</ServerSAP>
<ApplicationContextName>
<JointIsoCtt>2</JointIsoCtt>
<Country>16</Country>
<CountryName>756</CountryName>
<IdentifiedOrganization>5</IdentifiedOrganization>
<DlmsUA>8</DlmsUA>
<ApplicationContext>1</ApplicationContext>
<ContextId>1</ContextId>
</ApplicationContextName>
<XDLMSContextInfo>
<Conformance>16252928</Conformance>
<MaxReceivePduSize>1024</MaxReceivePduSize>
<MaxSendPduSize>1024</MaxSendPduSize>
<DlmsVersionNumber>6</DlmsVersionNumber>
</XDLMSContextInfo>
<AuthenticationMechanismName>
<DlmsUA>8</DlmsUA>
<AuthenticationMechanismName>2</AuthenticationMechanismName>
<MechanismId>2</MechanismId>
<Secret>67 75 72 75 78</Secret>
<AssociationStatus>2</AssociationStatus>
<SecuritySetupReference>0.0.43.0.0.255</SecuritySetupReference>
<Users>
</Users>
</GXDLMSAssociationLogicalName>
<GXDLMSData>
<Description>Meter Serial Number</Description>
<Access>11</Access>
<Value Type="9" UIType="10">INV000003</Value>
</GXDLMSData>
<GXDLMSClock>
<Time>08/12/2025 16:26:54</Time>
<Begin>*/*/2025 16:26:54</Begin>
<End>*/*/2025 16:26:54</End>
</GXDLMSClock>
<Buffer>
</Buffer>
<CaptureObjects>
<Item>
<ObjectType>1</ObjectType>
<Attribute>2</Attribute>
</Item>
</CaptureObjects>
<SortMethod>1</SortMethod>
</Objects>
4 months 4 weeks ago
Hi, Did you read the…
Did you read the association view again after you added the new COSEM object?
sethi.nitin9@g…
4 months ago
Hi Kurumi, Thanks it worked,…
Hi Kurumi,
Thanks it worked, and I am able to create template and access it with high association with password and able to read meter,
But I am having issue in reading same meter with authencrption while giving params in guruxdlmsdirector like title : MeterSys , authKey: MMMMMMMMMMMMMMMM, blockkey: MMMMMMMMMMMMMMMM but getting SEVERE: Decrypt failed. Invalid authentication tag.,
Below are the command line argument :
-h 127.0.0.1 -p 1000 -i WRAPPER -c 48 -a High -d India -t Verbose -x High_Template.xml -N 1 -P 8888888888888888 -C AuthenticationEncryption -T 4D65746572537973 -A 4D4D4D4D4D4D4D4D4D4D4D4D4D4D4D4D -B 4D4D4D4D4D4D4D4D4D4D4D4D4D4D4D4D
3 months 4 weeks ago
Hi, Are you using the Java…
Are you using the Java or C# version from the simulator?
sethi.nitin9@g…
Hi, I am using java from the…
I am using java from the simulator.
sethi.nitin9@g…
3 months 3 weeks ago
Hi Kurumi, Any updates…
Hi Kurumi,
Any updates regarding same problem?
3 months 2 weeks ago
Hi, Can you use the C#…
Can you use the C# version? The current Java version doesn't support key updating.
It's added to the next version.
sethi.nitin9@g…
Hi, I'll check that out but…
I'll check that out but can you please share the updates once you add that feature in java with new version?
Nitin
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
