  2. Connect To ISKRA Meter
Connect to ISKRA meter
By daniel.hinterlechner, 6 August, 2025
Gurux.Net
I was able to connect to an ISKRA MT880 meter via GXDLMSDirector with parameters: -h 172.18.54.201 -p 4002 -c 1 -s 164 -a Low -P 12345678 -d Italy -w 1 -f 154 -t Verbose
If I try with C# code I am not able to connect. What am I missing?
// Konfiguration für MT880 Zähler
string meterIpAddress = "172.18.54.201"; // Config 2 IP
int port = 4002;
int clientAddress = 1;
int serverAddress = 36;
string password = "12345678"; // Config 2 Passwort
// Netzwerk-Media
GXNet media = new GXNet()
Protocol = NetworkType.Tcp,
HostName = meterIpAddress,
Port = port,
WaitTime = 30000
// SendTimeout = 10000
// DLMS Client für MT880 (Config 2)
GXDLMSSecureClient client = new GXDLMSSecureClient(
useLogicalNameReferencing: true,
clientAddress: clientAddress,
serverAddress: serverAddress,
authentication: Authentication.Low, // DLMSAuthMethod=1
password: password,
interfaceType: InterfaceType.HDLC
client.HdlcSettings.MaxInfoRX = 154;
client.HdlcSettings.MaxInfoTX = 154;
client.Standard = Standard.Italy;
client.UseUtc2NormalTime=true; // UTC Zeit verwenden
7 months ago
CLOESD
CLOSED
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
  • GENUS sugam 3 PH bidirectional
