  2. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd, 28 July, 2025
Gurux DLMS for Android
i am using gurux android project where not able to connect with the usb prob
prob details given below
man info:Silicon Labs:CP2102
USB to UART bridge controller
chipset:CP21XX
serial:0001
Boud rate:9600
data bits:8
parity :none
stop bits :1
8 months 1 week ago
Hi, Are you getting any…
Are you getting any reply from the meter? Try to connect with GXDLMSDirector first.
There are a lot of settings that might be the reason why your meter does not reply. For example, the baud rate might be wrong.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
