  2. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd, 15 July, 2025
Gurux DLMS for Android
BLE communication and reading of current values (without association) work correctly on all meters.
DLMS association (SNRM + AARQ) over BLE works only with the LGZ meter — the meter responds to chunked requests, and we receive replies successfully.
However, on other meters, the same association flow over BLE (sending the association request in chunks) fails — we do not receive any response after sending the AARQ.
Over USB/serial (using the same authentication level LOW), all meters respond correctly to the association request.
We would like to know:
What could be the reason for the association failing over BLE on other meters?
Is there any specific BLE-related handling or configuration required in the Gurux library when sending association requests (especially in chunks)?
7 months 3 weeks ago
Hi, There is no BLE-related…
There is no BLE-related handling for Gurux library. If you are not receiving a reply from the meter.
With some meters, you might need to add a small delay (e.g., 1000 ms) before sending AARQ.
You can also try to use WRAPPER if your BLE is integrated into the meter.
  • Thu, 02/19/2026 - 11:51
    gurux.dlms.cpp 9.0.2602.1901
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Clou Meter CL730D22L connection
  • Gurux C library DLMS book edition support
  • Help with connection and read with landis+gyr e650 + CU-E22 using python
  • Preestablished connection
  • RJ11 to RS232 Pin out SECURE Premier 300
