  2. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd, 9 July, 2025
Gurux DLMS for Android
in android project profile buffer in billing profile
if i select from date and to date the buffer details is not coming
4 months 3 weeks ago
Hi, Can you read your meter…
Can you read your meter with GXDLMSDirector? If you can, add the hex trace from the read message so I can check what deviation your meter is using.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSClock
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
