I am using Arduino client code on ESP32 to read meter in MR mode with LLS.
I downloaded the latest version of Arduino and using MR association with encryption. I get a message on terminal as
<HT> :Start application<HT> :Start reading<HT> :Invocation Counter: 1793<HT> :com_initializeConnection SUCCEEDED 0<HT> :com_read failed. 285<HT> :Logical Device NameIndex: 2 Value: <LF>
<HT> :com_read failed. 285<HT> :com_read failed. 285<HT> :ClockIndex: 2 Value: 01/01/1970 00:00:00 UTC+00:00<LF>
Index: 3 Value: 0<LF>
Index: 4 Value: 0<LF>
Index: 5 Value: 01/01/1970 00:00:00 UTC+00:00<LF>
Index: 6 Value: 01/01/1970 00:00:00 UTC+00:00<LF>
Index: 7 Value: 0<LF>
Index: 8 Value: 0<LF>
Index: 9 Value: 0<LF>
Invocation counter is correct. Can you help me let know why is com_read() failing.?
I am using the following code.
void setup() {
pinMode(2, OUTPUT);
digitalWrite(2, HIGH);
//Serial 2 is used to send trace.
Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
while(!Serial2);
delay(100);
GXTRACE(GET_STR_FROM_EEPROM("Start application"), NULL);
BYTE_BUFFER_INIT(&frameData);
//Set frame capacity.
bb_capacity(&frameData, 128);
Client.init(true, 32, 1, DLMS_AUTHENTICATION_LOW, "NCCMSELL", DLMS_INTERFACE_TYPE_HDLC);
//Un-comment this if you want to set system title, block cipher key or authentication key.
Client.SetSecurity(DLMS_SECURITY_AUTHENTICATION_ENCRYPTION);
//TODO: Change logical name of the frame counter if it's used to com_readAllObjects.
gxByteBuffer bb;
bb_Init(&bb);
bb_addHexString(&bb, "3132333435363738");
Client.SetSystemTitle(&bb);
bb_clear(&bb);
bb_addHexString(&bb, "4E43434D534544434C637279705F454E");
Client.SetAuthenticationKey(&bb);
bb_clear(&bb);
Client.SetBlockCipherKey(&bb);
bb_clear(&bb);
Serial.begin(9600); // Optical Probe
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
GXTRACE(GET_STR_FROM_EEPROM("Start reading"), NULL);
//TODO: Change logical name of the frame counter if it's used.
int ret = com_readAllObjects("0.0.43.1.2.255"); //Invocation counter for MR association
com_close();
void loop()
Good Morning Sir, Can you…
Good Morning Sir, Can you please help here.
Hi, It looks like the…
It looks like the Logical Device Name read failed for some reason. I can't solve this without the hex trace.
Good Morning Sir, Can you advise how to take a hex dump. Is there a flag that can be enabled to produce the hex dump on debug port?
Hi, If you have two serial…
If you have two serial ports, you can send the hex trace to the other serial port.
Good Morning Sir, I added a…
Good Morning Sir,
I added a bit of code to get the trace in the int readDLMSPacket(gxByteBuffer* data, gxReplyData* reply) sub-routine.
The code looks like this
// Read DLMS Data frame from the device.
int readDLMSPacket(
gxByteBuffer* data,
gxReplyData* reply)
char* hex;
int resend = 0, ret = DLMS_ERROR_CODE_OK;
if (data->size == 0)
return DLMS_ERROR_CODE_OK;
reply->complete = 0;
frameData.size = 0;
frameData.position = 0;
//Send Trace
hex = bb_toHexString(data);
GXTRACE("TX:", hex);
GXTRACE("\n", NULL);
free(hex);
//Send data.
if ((ret = Serial.write(data->data, data->size)) != data->size)
//If failed to write all bytes.
GXTRACE(GET_STR_FROM_EEPROM("Failed to write all data to the serial port.\n"), NULL);
//Loop until packet is complete.
do
if ((ret = com_readSerialPort(0x7E)) != 0)
if (ret == DLMS_ERROR_CODE_RECEIVE_FAILED && resend == RESEND_COUNT)
return DLMS_ERROR_CODE_SEND_FAILED;
++resend;
GXTRACE_INT(GET_STR_FROM_EEPROM("Data send failed. Try to resend."), resend);
ret = Client.GetData(&frameData, reply);
if (ret != 0 && ret != DLMS_ERROR_CODE_FALSE)
break;
} while (reply->complete == 0);
hex=bb_toHexString(&frameData);
GXTRACE("RX:", hex);
return ret;
On the debug Serial Terminal I get the following dump
<HT> :Start application<HT> :Start reading<HT> :TX:7E A0 07 03 21 93 0F 01 7E<HT> :<LF>
<HT> :RX:7E A0 20 21 03 73 73 98 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E<HT> :<LF>
<HT> :TX:7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D FF FF E7 25 7E<HT> :<LF>
<HT> :RX:7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 EE 00 07 A6 F3 7E<HT> :<LF>
<HT> :TX:7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 02 FF 02 00 0B B6 7E<HT> :<LF>
<HT> :RX:7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 07 31 7F 75 7E<HT> :<LF>
<HT> :Invocation Counter: 1841<HT> :TX:7E A0 23 03 21 54 03 4E E6 E6 00 62 15 80 01 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D 02 EE CE 40 7E<HT> :<LF>
<HT> :RX:7E A0 0B 21 03 63 B4 C7 63 00 E3 B3 7E<HT> :<LF>
<HT> :TX:7E A0 07 03 21 53 03 C7 7E<HT> :<LF>
<HT> :TX:7E A0 07 03 41 93 5A 64 7E<HT> :<LF>
<HT> :RX:7E A0 20 41 03 73 3E 9D 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E<HT> :<LF>
<HT> :TX:7E A0 63 03 41 10 C1 39 E6 E6 00 60 55 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 4E 43 43 4D 53 45 4C 4C BE 23 04 21 21 1F 30 00 00 07 32 58 F9 3B 61 A2 68 60 3A C8 6C 3A 8E B6 DC 87 27 14 2F 29 5A 22 27 38 75 B9 E7 41 B2 7E<HT> :<LF>
<HT> :RX:7E A0 56 41 03 30 7E FC E6 E7 00 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 43 52 59 00 00 11 83 A5 BE 23 04 21 28 1F 30 00 00 07 32 11 1E 1E 6C 79 1E 78 5B 3F 93 9A 0B 66 BF C7 E3 43 4C 3B 22 E3 61 7D 42 16 06 58 75 7E<HT> :<LF>
<HT> :com_initializeConnection SUCCEEDED 0<HT> :TX:7E A0 2C 03 41 32 9F 9F E6 E6 00 C8 1E 30 00 00 07 33 B7 96 74 D7 23 65 91 6E 2E BA 76 13 02 78 26 80 1F D7 6E ED 08 2A 0E DC 3D 6C 77 7E<HT> :<LF>
<HT> :RX:7E A0 29 41 03 52 D6 54 E6 E7 00 CC 1B 20 00 00 07 33 F1 1D D5 8F F2 B5 ED 62 D6 2E 32 8E BC 80 E4 73 B8 65 2D C2 BB 32 F4 51 7E<HT> :<LF>
<HT> :TX:7E A0 2C 03 41 54 AF 99 E6 E6 00 C8 1E 30 00 00 07 34 E9 B4 B0 75 EB 65 1D 4C AA B5 B9 43 2A 0F 10 ED E6 AD EB F2 61 EC 14 87 C6 FD 17 7E<HT> :<LF>
<HT> :RX:7E A0 1A 41 03 74 DD 79 E6 E7 00 CC 0C 20 00 00 07 34 9A 7B CF 84 EB 0D F9 27 4A 7E<HT> :<LF>
<HT> :com_read failed. 285<HT> :TX:7E A0 2C 03 41 76 BF 9B E6 E6 00 C8 1E 30 00 00 07 35 07 62 50 60 03 C6 B1 12 FC 29 12 02 58 1A D6 BC CB 0C 77 39 17 DC C3 B2 DB C3 CA 7E<HT> :<LF>
<HT> :RX:7E A0 25 41 03 96 CA 43 E6 E7 00 CC 17 20 00 00 07 35 E4 DA AE 93 07 BE DD DB 6A 09 FD C8 5C AF DF 0D 39 8D 2D 95 7E<HT> :<LF>
<HT> :TX:7E A0 36 03 41 98 C0 8A E6 E6 00 62 28 80 01 00 BE 23 04 21 21 1F 30 00 00 07 36 0D EE 0A 5D 41 CE 1B 42 80 FC 0C 7D 8C 42 18 1A 35 26 8A AD 0A 34 F5 9B 8D B7 97 AB 7E<HT> :<LF>
<HT> :RX:7E A0 0B 41 03 63 F9 C2 63 00 E3 B3 7E<HT> :<LF>
<HT> :TX:7E A0 07 03 41 53 56 A2 7E<HT> :<LF>
Please help to identify the failure of Logical Device Name read if this data is correct or advise the correct code snippet to get the correct dump.
Best Regards
Hi, You start to communicate…
You start to communicate using AuthenticationEncryption, but the meter returns only encrypted data. The authentication tag is missing, and the received data is not accepted. Ask the meter manufacturer if there is a firmware update available.
Thank you Sir, I ran the…
Thank you Sir,
I ran the Gurux Python on the same meter and it shows correct loginal name with no errors.
Here is the dump. Arduino code should also produce the same result. Any advise if I am missing anything.?
PS D:\KIGG\GURUX-06-06-2025\Gurux.DLMS.Python-master\Gurux.DLMS.Client.Example.python> python main.py -S COM7:9600:8None1 -c 32 -a Low -P NCCMSELL -C Encryption -T 4142434445464748 -A 4E43434D534544434C637279705F454E -B 4E43434D534544434C637279705F454E -v 0.0.43.1.2.255 -d India -t Verbose
gurux_dlms version: 1.0.181
gurux_net version: 1.0.22
gurux_serial version: 1.0.21
Authentication: 1
ClientAddress: 0x20
Standard: 1
Security: 32
System title: 41 42 43 44 45 46 47 48
Authentication key: 4E 43 43 4D 53 45 44 43 4C 63 72 79 70 5F 45 4E
Block cipher key: 4E 43 43 4D 53 45 44 43 4C 63 72 79 70 5F 45 4E
TX: 12:52:57 7E A0 07 03 21 93 0F 01 7E
RX: 12:52:57 7E A0 20 21 03 73 73 98 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
TX: 12:52:57 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF 91 23 7E
RX: 12:52:58 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 EE 00 07 A6 F3 7E
TX: 12:52:58 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 02 FF 02 00 0B B6 7E
RX: 12:52:58 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 07 43 EA 25 7E
Invocation counter: 1860
TX: 12:52:58 7E A0 07 03 21 53 03 C7 7E
RX: 12:52:58 7E A0 20 21 03 73 73 98 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
TX: 12:52:58 7E A0 07 03 41 93 5A 64 7E
RX: 12:52:58 7E A0 20 41 03 73 3E 9D 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
TX: 12:52:58 7E A0 57 03 41 10 DF 07 E6 E6 00 60 49 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 4E 43 43 4D 53 45 4C 4C BE 17 04 15 21 13 20 00 00 07 44 71 AB C4 B4 8D 04 90 CF 84 E4 33 E3 A8 BD A8 E8 7E
RX: 12:52:59 7E A0 4A 41 03 30 EB A8 E6 E7 00 61 3C A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 43 52 59 00 00 11 83 A5 BE 17 04 15 28 13 20 00 00 07 44 5A 1C 8D 50 DA 3A 7F 9E 02 7E C5 27 CE 4E 45 EF 7E
Decrypted PDU: C0 01 C1 00 01 00 00 2A 00 00 FF 02 00
<GetRequest>
<GetRequestNormal>
<AttributeDescriptor>
<ClassId Value="0001" />
<InstanceId Value="00002A0000FF" />
<AttributeId Value="02" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
TX: 12:52:59 7E A0 20 03 41 32 AB 08 E6 E6 00 C8 12 20 00 00 07 45 64 F4 18 8F 42 A1 9C 40 09 66 2A 44 18 69 44 7E
Decrypted PDU: C4 01 C1 00 0A 10 43 52 59 30 30 30 30 4D 48 31 31 34 37 38 31 33
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<String Value="CRY0000MH1147813" />
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
RX: 12:52:59 7E A0 29 41 03 52 D6 54 E6 E7 00 CC 1B 20 00 00 07 45 67 6C 28 60 3C 20 93 09 41 4C 40 3A CD 6C 5D 25 13 A6 14 6F 61 94 BC 68 7E
CRY0000MH1147813
TX: 12:52:59 7E A0 11 03 41 54 D2 5E E6 E6 00 62 03 80 01 00 BD 9B 7E
RX: 12:52:59 7E A0 0B 41 03 63 F9 C2 63 00 E3 B3 7E
TX: 12:52:59 7E A0 07 03 41 53 56 A2 7E
RX: 12:52:59 7E A0 20 41 03 73 3E 9D 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
Hi, You are using Encryption…
You are using Encryption in Python and DLMS_SECURITY_AUTHENTICATION_ENCRYPTION in ANSI C.
You need to fix that.
You are right sir. I…
You are right sir. I corrected to DLMS_SECURITY_ENCRYPTION and now I am able to read Data Objects correctly like Make , Serial Number. But when I use Data type as register the com_read fails and the dump is like this
12-06-2025 17:00:34.296 [RX] - Start Application<HT> :TX:7E A0 07 03 21 93 0F 01 7E<HT> :<LF>
<HT> :RX:7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 08 25 12 A0 7E<HT> :<LF>
<HT> :Invocation Counter: 2085<HT> :TX:7E A0 23 03 21 54 03 4E E6 E6 00 62 15 80 01 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D 02 EE CE 40 7E<HT> :<LF>
<HT> :TX:7E A0 57 03 41 10 DF 07 E6 E6 00 60 49 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 4E 43 43 4D 53 45 4C 4C BE 17 04 15 21 13 20 00 00 08 26 5A 02 41 90 8D 1D DB A4 0C A0 B7 5B 8F 1F 74 18 7E<HT> :<LF>
<HT> :RX:7E A0 4A 41 03 30 EB A8 E6 E7 00 61 3C A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 43 52 59 00 00 11 83 A5 BE 17 04 15 28 13 20 00 00 08 26 03 2F 1C A6 0F 0E B3 46 10 8B A2 F6 C9 EE C3 9C 7E<HT> :<LF>
<HT> :TX:7E A0 20 03 41 32 AB 08 E6 E6 00 C8 12 20 00 00 08 27 6B 85 5B EE 60 DB D2 8B D2 87 70 83 86 CF 76 7E<HT> :<LF>
<HT> :RX:7E A0 1D 41 03 52 C8 6A E6 E7 00 CC 0F 20 00 00 08 27 1D A1 11 BE 3F 5A 7E 8E 68 63 4E 46 7E<HT> :<LF>
<HT> :TX:7E A0 20 03 41 54 9B 0E E6 E6 00 C8 12 20 00 00 08 28 BC 01 79 64 8D FA 7D CE AF 5C 82 D5 77 AF 73 7E<HT> :<LF>
<HT> :RX:7E A0 1C 41 03 74 47 32 E6 E7 00 CC 0E 20 00 00 08 28 87 F3 69 B8 87 33 70 A2 A6 00 AC 7E<HT> :<LF>
<HT> :com_read failed. 2580.000000 KWh<HT> :TX:7E A0 2A 03 41 76 25 D0 E6 E6 00 62 1C 80 01 00 BE 17 04 15 21 13 20 00 00 08 29 7E 1A D0 1A FA 72 79 2F 13 AB E7 50 AA 6D 0E 2F 7E<HT> :<LF>
The code used was
int com_readActive()
int ret;
char str[50];
char* data = NULL;
float scale;
float active_energy,reactive_energy,apparent_energy;
//Initialize connection.
GXTRACE_INT(PSTR("F"), ret);
return ret;
gxRegister reg1;
cosem_init(BASE(reg1), DLMS_OBJECT_TYPE_REGISTER, "1.0.1.8.0.255"); // OBis for Cum Active Energy (Imp)
com_read(BASE(reg1), 3); // Read Scaler and Units
com_read(BASE(reg1), 2); // Read Value
active_energy= var_toInteger(®1.value) *pow(10, reg1.scaler); // Read Active Energy Value by using var_toInteger()
sprintf(str, "%f KWh", active_energy);
Serial2.print(str);
obj_clear(BASE(reg1));
free(data);
com_close();
Request you to help with this error.
Thank You and Regards
Good Morning Sir, Could you…
Good Morning Sir,
Could you take a look at this latest issue where I am able to read the data objects but not register objects using ciper.?
Thank You
Hi, Your meter is returning…
Your meter is returning float value and you don't need to convert it to an integer.
Change this line:
to this:
active_energy= reg1.value.fltVal *pow(10, reg1.scaler);
Thank You Sir, I will do the…
Thank You Sir,
I tried but there is a error like this
error: 'dlmsVARIANT' {aka 'struct tagdlmsVARIANT'} has no member named 'fltVal'
1112 | active_energy=reg1.value.fltVal * pow(10, reg1.scaler);
Please advise
I also tried to check the type of data using reg1.value.vt but
Thank you and best regards
Here is the hex dump
Start Application<HT> :Start reading<HT> :TX:7E A0 07 03 21 93 0F 01 7E<HT> :<LF>
<HT> :RX:7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 08 CA EB BF 7E<HT> :<LF>
<HT> :Invocation Counter: 2250<HT> :TX:7E A0 23 03 21 54 03 4E E6 E6 00 62 15 80 01 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 1D 02 EE CE 40 7E<HT> :<LF>
<HT> :TX:7E A0 57 03 41 10 DF 07 E6 E6 00 60 49 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 4E 43 43 4D 53 45 4C 4C BE 17 04 15 21 13 20 00 00 08 CB 44 DA F2 81 A1 FC E2 A0 AD 77 84 3C F0 D2 96 10 7E<HT> :<LF>
<HT> :RX:7E A0 4A 41 03 30 EB A8 E6 E7 00 61 3C A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 43 52 59 00 00 11 83 A5 BE 17 04 15 28 13 20 00 00 08 CB CF EC E8 5F B7 27 CB 56 93 83 29 50 16 08 7C 88 7E<HT> :<LF>
<HT> :com_initializeConnection SUCCEEDED 0<HT> :TX:7E A0 20 03 41 32 AB 08 E6 E6 00 C8 12 20 00 00 08 CC 80 0C 15 C2 19 94 4F CE 21 BF 58 8E 61 F6 57 7E<HT> :<LF>
<HT> :RX:7E A0 2F 41 03 52 4C 1F E6 E7 00 CC 21 20 00 00 08 CC A1 A6 C2 3C 97 D7 08 2A B8 A7 B6 DB 3E 9C 9D F9 3D 18 39 F6 02 3E 22 42 AE 6A 7C C0 A9 89 7E<HT> :<LF>
<HT> :Meter Make:Index: 2 Value: Sinhal Udyog Pvt. Ltd.<LF>
<HT> :TX:7E A0 20 03 41 54 9B 0E E6 E6 00 C8 12 20 00 00 08 CD 6F 04 CB 08 AD BC 39 51 C1 0B F6 D1 8C A3 B3 7E<HT> :<LF>
<HT> :RX:7E A0 1A 41 03 74 DD 79 E6 E7 00 CC 0C 20 00 00 08 CD 09 B3 CD 19 16 B5 D8 A0 4A 7E<HT> :<LF>
<HT> :TX:7E A0 20 03 41 76 8B 0C E6 E6 00 C8 12 20 00 00 08 CE EA CF 49 4B F3 AF F3 FC FF 70 ED 00 BE 0C 54 7E<HT> :<LF>
<HT> :RX:7E A0 25 41 03 96 CA 43 E6 E7 00 CC 17 20 00 00 08 CE BD 2E B0 29 6A E2 48 8B 5D 32 1C 57 E1 BF 66 BD 0E 1A 26 E1 7E<HT> :<LF>
<HT> :ClockIndex: 2 Value: 06/16/2025 20:19:34 UTC+05:30<LF>
Index: 3 Value: -330<LF>
<HT> :TX:7E A0 20 03 41 98 FB 02 E6 E6 00 C8 12 20 00 00 08 CF 8F 54 80 1A 04 5F 6E E0 16 07 96 EA 59 40 77 7E<HT> :<LF>
<HT> :RX:7E A0 1D 41 03 B8 9C 22 E6 E7 00 CC 0F 20 00 00 08 CF 4F 19 05 6F 72 B7 A5 D1 96 41 DB 7C 7E<HT> :<LF>
<HT> :TX:7E A0 20 03 41 BA EB 00 E6 E6 00 C8 12 20 00 00 08 D0 D4 96 FA 10 15 9B CF DB A9 AB 74 36 6A A2 75 7E<HT> :<LF>
<HT> :RX:7E A0 1C 41 03 DA 33 7E E6 E7 00 CC 0E 20 00 00 08 D0 C7 42 45 E2 3D 0F 43 BF C5 D7 66 7E<HT> :<LF>
Hi, You don't read the…
You don't read the register in your last trace, and it doesn't give any information.
Check if you have defined DLMS_IGNORE_FLOAT32 in your code.
