Dear Mikko,
Related to an itron (SL7000) meter's reading, it was observed a slight inaccuracy of conversion from hex to readings from programming (C#), as opposed to displaying values from Director.
For eg. This below, is the hex trace of one portion of the reading:
RX: 7E A8 8C 0F 00 02 00 23 B0 75 5C 91 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 04 4E 05 00 00 00 00 05 00 00 03 07 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 02 48 05 00 00 00 00 05 00 00 03 09 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 00 B8 05 00 00 00 05 05 00 00 03 05 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 0B 75 7E
From the Director, we can get the readings as below:
1102 0 775 0 660 657 658
584 0 777 0 660 657 657
184 5 773 0 661 658 658
But from programming, using the usual ReadDataBlock() and then UpdateValue(), we get the following, which is slightly different from the Director, and I think based on the hex dump, the programming library is slightly inaccurate as below:
1101 0 775 0 659 658 658
584 0 776 0 659 658 657
184 5 774 0 660 659 658
Curiously, the DateTime column are ok so far (Note that in this hex dump, the datetime is null, but this is not a problem here.).
Was there something else that I need to further convert?
Please advise.
Thanks.
Jason
Hi, The trace doesn't help…
The trace doesn't help because it only shows a small part of the data.
GXDSLMDirector is using a C# library, so the readings should match.
Hi Mikko, Understood your…
Understood your concern. I shall furnish the trace as below, but it is a bit lengthy...
The main point is that from the hex, if we convert to the numbers, it will be different than the output that we get when we read from the dataarray[][] after UpdateValue().
TX: 7E A0 4F 00 02 00 23 0F 96 33 A8 E6 E6 00 C0 01 C1 00 07 00 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E9 05 1D FF 00 00 00 FF FE 20 00 09 0C 07 E9 06 01 FF 00 00 00 FF FE 20 00 01 00 4B F9 7E
RX: 7E A8 8C 0F 00 02 00 23 98 3F F1 E6 E7 00 C4 02 C1 00 00 00 00 01 00 82 08 A5 01 82 00 90 02 0B 02 02 09 0C 07 E9 05 1D FF FF FF FF FF 80 00 FF 04 06 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 9F 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A0 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8E 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 0D D5 7E
TX: 7E A0 0A 00 02 00 23 0F B1 2B CA 7E
RX: 7E A8 8C 0F 00 02 00 23 9A 2D D2 00 00 05 00 00 00 0D 05 00 00 03 9D 05 00 00 00 00 05 00 00 02 90 05 00 00 02 8D 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A3 05 00 00 00 00 05 00 00 02 92 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A4 05 00 00 00 00 05 00 00 02 93 05 00 00 02 90 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 D5 73 7E
TX: 7E A0 0A 00 02 00 23 0F D1 2D A9 7E
RX: 7E A8 8C 0F 00 02 00 23 9C 1B B7 00 0D 05 00 00 03 9E 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A1 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 A1 05 00 00 00 00 05 00 00 02 92 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 13 9F 7E
TX: 7E A0 0A 00 02 00 23 0F F1 2F 88 7E
RX: 7E A8 8C 0F 00 02 00 23 9E 09 94 03 A5 05 00 00 00 00 05 00 00 02 93 05 00 00 02 90 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A9 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A7 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A7 05 00 00 FD B8 7E
TX: 7E A0 0A 00 02 00 23 0F 11 21 6F 7E
RX: 7E A8 8C 0F 00 02 00 23 90 77 7D 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 A6 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 A9 05 00 00 00 00 05 00 00 02 96 05 00 00 02 93 05 00 00 02 94 02 0B 00 00 00 00 05 00 00 00 D2 05 00 00 00 03 05 00 00 03 2A 05 00 00 00 00 05 00 00 77 7D 7E
TX: 7E A0 0A 00 02 00 23 0F 31 23 4E 7E
RX: 7E A8 8C 0F 00 02 00 23 92 65 5E 02 97 05 00 00 02 95 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 05 7D 05 00 00 00 00 05 00 00 03 12 05 00 00 00 00 05 00 00 02 95 05 00 00 02 93 05 00 00 02 94 02 0B 00 00 00 00 05 00 00 0B 06 05 00 00 00 00 05 00 00 02 F3 05 00 00 00 00 05 00 00 02 93 05 00 00 02 90 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 0D 01 05 00 00 00 00 05 00 00 02 E3 05 00 00 00 00 05 00 00 02 91 05 00 00 F1 CB 7E
TX: 7E A0 0A 00 02 00 23 0F 51 25 2D 7E
RX: 7E A8 8C 0F 00 02 00 23 94 53 3B 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 0D BD 05 00 00 00 00 05 00 00 02 DC 05 00 00 00 00 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 1E 3A 05 00 00 00 00 05 00 00 01 E3 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 2E 3C 05 00 00 00 00 05 00 00 00 7E 05 00 00 00 1F 05 00 00 02 91 05 00 00 02 8F 05 00 00 0C D6 7E
TX: 7E A0 0A 00 02 00 23 0F 71 27 0C 7E
RX: 7E A8 8C 0F 00 02 00 23 96 41 18 02 8F 02 0B 00 00 00 00 05 00 00 34 7F 05 00 00 00 00 05 00 00 00 2F 05 00 00 00 9E 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 29 EC 05 00 00 00 00 05 00 00 00 EF 05 00 00 00 34 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 2A 76 05 00 00 00 00 05 00 00 00 BC 05 00 00 00 02 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8B 02 0B 00 A6 8A 7E
TX: 7E A0 0A 00 02 00 23 0F 91 29 EB 7E
RX: 7E A8 8C 0F 00 02 00 23 98 3F F1 00 00 00 05 00 00 30 C0 05 00 00 00 00 05 00 00 00 2E 05 00 00 00 2F 05 00 00 02 8F 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 35 BF 05 00 00 00 00 05 00 00 00 20 05 00 00 00 C9 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 28 1E 05 00 00 00 00 05 00 00 01 02 05 00 00 00 20 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 D3 DB 7E
RX: 7E A8 8C 0F 00 02 00 23 9A 2D D2 00 28 8D 05 00 00 00 00 05 00 00 00 FC 05 00 00 00 4E 05 00 00 02 8D 05 00 00 02 8B 05 00 00 02 8B 02 0B 00 00 00 00 05 00 00 1E 2B 05 00 00 00 00 05 00 00 01 CF 05 00 00 00 07 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 37 D7 05 00 00 00 00 05 00 00 00 08 05 00 00 00 F6 05 00 00 02 8F 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 34 4C 05 00 B3 57 7E
RX: 7E A8 8C 0F 00 02 00 23 9C 1B B7 00 00 00 05 00 00 00 25 05 00 00 00 A0 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 29 1F 05 00 00 00 00 05 00 00 01 11 05 00 00 00 59 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8B 02 0B 00 00 00 00 05 00 00 2D B1 05 00 00 00 00 05 00 00 00 9A 05 00 00 00 53 05 00 00 02 8C 05 00 00 02 8A 05 00 00 02 8A 02 0B 00 00 00 00 05 00 00 18 86 05 00 00 00 00 05 00 EB 66 7E
RX: 7E A8 8C 0F 00 02 00 23 9E 09 94 00 02 2F 05 00 00 00 10 05 00 00 02 95 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 06 DF 05 00 00 00 00 05 00 00 03 06 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 94 02 0B 00 00 00 00 05 00 00 03 20 05 00 00 00 00 05 00 00 03 15 05 00 00 00 00 05 00 00 02 98 05 00 00 02 95 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 D9 05 00 00 00 00 05 00 00 03 0F 05 00 0E 5A 7E
RX: 7E A8 8C 0F 00 02 00 23 90 77 7D 00 00 00 05 00 00 02 99 05 00 00 02 96 05 00 00 02 97 02 0B 00 00 00 00 05 00 00 00 7D 05 00 00 00 01 05 00 00 03 0C 05 00 00 00 00 05 00 00 02 98 05 00 00 02 95 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 14 05 00 00 03 78 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 A5 05 00 00 00 00 05 00 50 1E 7E
RX: 7E A8 8C 0F 00 02 00 23 92 65 5E 00 02 95 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 A5 05 00 00 00 00 05 00 00 02 94 05 00 00 02 90 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A8 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 AD 05 00 00 00 00 05 00 00 02 98 05 00 A7 0C 7E
RX: 7E A8 8C 0F 00 02 00 23 94 53 3B 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B7 05 00 00 00 00 05 00 00 02 9C 05 00 00 02 98 05 00 00 02 99 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 B8 05 00 00 00 00 05 00 00 02 9C 05 00 00 02 99 05 00 00 02 9A 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 BC 05 00 00 00 00 05 00 00 02 9E 05 00 00 02 9A 05 00 AA C7 7E
RX: 7E A8 8C 0F 00 02 00 23 96 41 18 00 02 9B 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 BC 05 00 00 00 00 05 00 00 02 9E 05 00 00 02 9A 05 00 00 02 9B 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 BF 05 00 00 00 00 05 00 00 02 9F 05 00 00 02 9B 05 00 00 02 9C 02 0B 02 02 09 0C 07 E9 05 1E FF FF FF FF FF 80 00 FF 04 06 00 00 00 00 05 00 00 00 00 05 00 00 00 10 05 00 00 03 BE 05 00 00 00 2C 19 7E
RX: 7E A8 8C 0F 00 02 00 23 98 3F F1 00 05 00 00 02 9F 05 00 00 02 9C 05 00 00 02 9C 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B2 05 00 00 00 00 05 00 00 02 99 05 00 00 02 96 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AB 05 00 00 00 00 05 00 00 02 96 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A8 05 00 00 00 00 05 00 00 02 40 91 7E
RX: 7E A0 40 0F 00 02 00 23 9A 10 0F 94 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 A7 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 92 AF 85 7E
TX: 7E A0 16 00 02 00 23 0F D8 BF 30 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
RX: 7E A8 8C 0F 00 02 00 23 BC 19 96 E6 E7 00 C4 02 C1 00 00 00 00 02 00 82 08 8F 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AD 05 00 00 00 00 05 00 00 02 96 05 00 00 02 93 05 00 00 02 94 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AF 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 AF 05 00 00 00 00 05 00 00 02 97 C8 87 7E
RX: 7E A8 8C 0F 00 02 00 23 BE 0B B5 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 97 05 00 00 02 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 97 05 00 00 02 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 98 05 00 00 02 95 D5 44 7E
RX: 7E A8 8C 0F 00 02 00 23 B0 75 5C 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 97 05 00 00 02 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 AD 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AA 05 00 00 00 00 05 00 00 02 96 05 00 00 02 94 05 00 00 02 95 E2 DC 7E
RX: 7E A8 8C 0F 00 02 00 23 B2 67 7F 02 0B 00 00 00 00 05 00 00 01 20 05 00 00 00 01 05 00 00 03 16 05 00 00 00 00 05 00 00 02 95 05 00 00 02 93 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 04 DC 05 00 00 00 00 05 00 00 03 18 05 00 00 00 00 05 00 00 02 94 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 06 F4 05 00 00 00 00 05 00 00 03 0B 05 00 00 00 00 05 00 00 02 93 05 00 00 02 90 05 00 00 02 91 02 0B 00 00 00 20 6B 7E
RX: 7E A8 8C 0F 00 02 00 23 B4 51 1A 00 05 00 00 0B 35 05 00 00 00 00 05 00 00 02 F1 05 00 00 00 00 05 00 00 02 92 05 00 00 02 90 05 00 00 02 90 02 0B 00 00 00 00 05 00 00 0E FB 05 00 00 00 00 05 00 00 02 D6 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 11 7A 05 00 00 00 00 05 00 00 02 BB 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 17 13 6A 7E
RX: 7E A8 8C 0F 00 02 00 23 B6 43 39 52 05 00 00 00 00 05 00 00 02 6E 05 00 00 00 00 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 21 6A 05 00 00 00 00 05 00 00 01 B3 05 00 00 00 00 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 2C 01 05 00 00 00 00 05 00 00 00 BF 05 00 00 00 19 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 30 2F 05 00 00 00 2E F8 7E
RX: 7E A8 8C 0F 00 02 00 23 B8 3D D0 00 05 00 00 00 74 05 00 00 00 54 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 2A B8 05 00 00 00 00 05 00 00 00 CE 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 26 23 05 00 00 00 00 05 00 00 01 47 05 00 00 00 0C 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 39 7F 05 00 00 00 00 05 00 00 00 03 64 7E
RX: 7E A8 8C 0F 00 02 00 23 BA 2F F3 00 05 00 00 01 25 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 35 F2 05 00 00 00 00 05 00 00 00 00 05 00 00 00 AA 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 32 FF 05 00 00 00 00 05 00 00 00 1B 05 00 00 00 65 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 29 35 05 00 00 00 00 05 00 00 00 EC 05 00 00 00 2A CD 7E
RX: 7E A8 8C 0F 00 02 00 23 BC 19 96 0C 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 2F 17 05 00 00 00 00 05 00 00 00 95 05 00 00 00 7A 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 2E 6D 05 00 00 00 00 05 00 00 00 8B 05 00 00 00 57 05 00 00 02 8F 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 32 A8 05 00 00 00 00 05 00 00 00 40 05 00 00 00 8C 05 00 00 02 4C 8D 7E
RX: 7E A8 8C 0F 00 02 00 23 BE 0B B5 8F 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 22 FC 05 00 00 00 00 05 00 00 01 75 05 00 00 00 02 05 00 00 02 91 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 19 DA 05 00 00 00 00 05 00 00 02 39 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 0A C8 05 00 00 00 00 05 00 00 02 E8 05 00 00 00 00 05 00 00 02 94 05 00 00 02 10 00 7E
RX: 7E A8 8C 0F 00 02 00 23 B2 67 7F 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 1C 05 00 00 03 65 05 00 00 00 00 05 00 00 02 95 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 A5 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A6 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 92 02 0B 00 00 36 50 7E
RX: 7E A8 8C 0F 00 02 00 23 B4 51 1A 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 AC 05 00 00 00 00 05 00 00 02 98 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AF 05 00 00 00 00 05 00 00 02 99 05 00 00 02 95 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 9A 05 00 00 02 96 05 00 00 02 97 02 0B 00 00 00 00 05 00 00 B3 B2 7E
RX: 7E A8 8C 0F 00 02 00 23 B6 43 39 00 00 05 00 00 00 0E 05 00 00 03 B2 05 00 00 00 00 05 00 00 02 9A 05 00 00 02 97 05 00 00 02 97 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 B5 05 00 00 00 00 05 00 00 02 9C 05 00 00 02 98 05 00 00 02 99 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B5 05 00 00 00 00 05 00 00 02 9C 05 00 00 02 99 05 00 00 02 9A 02 0B 02 02 09 0C 07 E9 05 1F FF FF FF FF 65 EF 7E
RX: 7E A8 8C 0F 00 02 00 23 B8 3D D0 FF 80 00 FF 04 06 00 00 00 00 05 00 00 00 00 05 00 00 00 10 05 00 00 03 B9 05 00 00 00 00 05 00 00 02 9E 05 00 00 02 9A 05 00 00 02 9B 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AE 05 00 00 00 00 05 00 00 02 98 05 00 00 02 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A5 05 00 00 00 00 05 00 00 02 93 05 00 00 02 90 05 00 00 02 91 02 DF 2E 7E
RX: 7E A8 8C 0F 00 02 00 23 BA 2F F3 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 A6 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 B2 05 00 00 00 00 05 00 00 02 99 05 00 00 02 96 05 00 00 02 97 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B7 05 00 00 00 00 05 00 00 02 9B 05 00 00 02 98 05 00 00 02 99 02 0B 00 00 00 00 55 95 7E
RX: 7E A8 8C 0F 00 02 00 23 BC 19 96 05 00 00 00 00 05 00 00 00 10 05 00 00 03 B9 05 00 00 00 00 05 00 00 02 9D 05 00 00 02 9A 05 00 00 02 9B 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 BE 05 00 00 00 00 05 00 00 02 9E 05 00 00 02 9B 05 00 00 02 9D 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AC 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 2B A8 7E
RX: 7E A0 2A 0F 00 02 00 23 BE E4 25 05 00 00 00 0E 05 00 00 03 AE 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 8D 6E 7E
TX: 7E A0 16 00 02 00 23 0F 1A A1 D5 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
RX: 7E A8 8C 0F 00 02 00 23 D0 73 3F E6 E7 00 C4 02 C1 01 00 00 00 03 00 82 06 16 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AD 05 00 00 00 00 05 00 00 02 96 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AA 05 00 00 00 00 05 00 00 02 95 05 00 00 02 93 05 00 00 02 94 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A9 05 00 00 00 00 05 00 00 02 95 42 2C 7E
RX: 7E A8 8C 0F 00 02 00 23 D2 61 1C 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 A4 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 01 45 05 00 00 00 00 05 00 00 03 1A 05 00 00 00 00 05 00 00 02 97 05 00 00 02 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 05 F4 05 00 00 00 00 05 00 00 03 1F 05 00 00 00 00 05 00 00 02 98 05 00 00 02 95 8F F9 7E
RX: 7E A8 8C 0F 00 02 00 23 D4 57 79 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 07 57 05 00 00 00 00 05 00 00 03 0F 05 00 00 00 00 05 00 00 02 96 05 00 00 02 94 05 00 00 02 94 02 0B 00 00 00 00 05 00 00 0F 62 05 00 00 00 00 05 00 00 02 C2 05 00 00 00 00 05 00 00 02 95 05 00 00 02 93 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 21 95 05 00 00 00 00 05 00 00 01 BE 05 00 00 00 00 05 00 00 02 94 05 00 00 02 92 05 00 00 02 92 87 F8 7E
RX: 7E A8 8C 0F 00 02 00 23 D6 45 5A 02 0B 00 00 00 00 05 00 00 29 10 05 00 00 00 00 05 00 00 01 0D 05 00 00 00 00 05 00 00 02 93 05 00 00 02 92 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 2F AF 05 00 00 00 00 05 00 00 00 46 05 00 00 00 03 05 00 00 02 92 05 00 00 02 90 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 35 7E 05 00 00 00 00 05 00 00 00 00 05 00 00 00 88 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8E 02 0B 00 00 00 CB C9 7E
RX: 7E A8 8C 0F 00 02 00 23 D8 3B B3 00 05 00 00 39 BA 05 00 00 00 00 05 00 00 00 00 05 00 00 01 2D 05 00 00 02 8F 05 00 00 02 8E 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 39 D0 05 00 00 00 00 05 00 00 00 00 05 00 00 01 3B 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 37 C4 05 00 00 00 00 05 00 00 00 07 05 00 00 00 F8 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 32 35 66 7E
RX: 7E A8 8C 0F 00 02 00 23 DA 29 90 14 05 00 00 00 00 05 00 00 00 79 05 00 00 00 D8 05 00 00 02 90 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 2B 04 05 00 00 00 00 05 00 00 00 F2 05 00 00 00 97 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 22 DF 05 00 00 00 00 05 00 00 01 75 05 00 00 00 01 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8B 02 0B 00 00 00 00 05 00 00 31 58 05 00 00 00 7B 11 7E
RX: 7E A8 8C 0F 00 02 00 23 DC 1F F5 00 05 00 00 00 75 05 00 00 00 A6 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 30 0B 05 00 00 00 00 05 00 00 00 73 05 00 00 00 79 05 00 00 02 8D 05 00 00 02 8A 05 00 00 02 8B 02 0B 00 00 00 00 05 00 00 11 75 05 00 00 00 00 05 00 00 02 96 05 00 00 00 00 05 00 00 02 90 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 05 89 05 00 00 00 00 05 00 00 03 FF 91 7E
RX: 7E A8 8C 0F 00 02 00 23 DE 0D D6 00 05 00 00 00 00 05 00 00 02 96 05 00 00 02 93 05 00 00 02 94 02 0B 00 00 00 00 05 00 00 01 9D 05 00 00 00 00 05 00 00 03 0C 05 00 00 00 00 05 00 00 02 94 05 00 00 02 92 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 02 88 05 00 00 00 00 05 00 00 03 10 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 01 BB 05 00 00 00 00 05 00 00 03 1A 05 00 00 00 F0 EB 7E
RX: 7E A8 8C 0F 00 02 00 23 D0 73 3F 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 01 BD 05 00 00 00 00 05 00 00 03 19 05 00 00 00 00 05 00 00 02 98 05 00 00 02 95 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 02 7B 05 00 00 00 00 05 00 00 03 20 05 00 00 00 00 05 00 00 02 99 05 00 00 02 97 05 00 00 02 97 02 0B 00 00 00 00 05 00 00 03 B6 05 00 00 00 00 05 00 00 03 1F 05 00 00 00 00 05 00 00 02 5C 54 7E
RX: 7E A8 8C 0F 00 02 00 23 D2 61 1C 9A 05 00 00 02 97 05 00 00 02 98 02 0B 00 00 00 00 05 00 00 01 79 05 00 00 00 01 05 00 00 03 19 05 00 00 00 00 05 00 00 02 99 05 00 00 02 96 05 00 00 02 97 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 23 05 00 00 03 53 05 00 00 00 00 05 00 00 02 99 05 00 00 02 95 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 AF 05 00 00 00 00 05 00 00 02 98 05 00 00 02 A9 7C 7E
RX: 7E A8 8C 0F 00 02 00 23 D4 57 79 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AF 05 00 00 00 00 05 00 00 02 98 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 B4 05 00 00 00 00 05 00 00 02 9A 05 00 00 02 96 05 00 00 02 97 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B3 05 00 00 00 00 05 00 00 02 9A 05 00 00 02 96 05 00 00 02 FB 37 7E
RX: 7E A8 8C 0F 00 02 00 23 D6 45 5A 97 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 BA 05 00 00 00 00 05 00 00 02 9C 05 00 00 02 98 05 00 00 02 99 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 BD 05 00 00 00 00 05 00 00 02 9E 05 00 00 02 9A 05 00 00 02 9B 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 BC 05 00 00 00 00 05 00 00 02 9E 05 00 00 02 9B 05 00 00 02 9B 02 0B 00 00 C1 45 7E
Thanks.
Dear Mikko, Instead of the…
Dear Mikko,
Instead of the previous long hex dump, I'll paste here the one day data for your convenience, in particular, please note the 12th RX block where it showed value of "04 4E" which corresponds to "1102". This is also the value shown in Director.
However, after using the usual ReadDataBlock() and then UpdateValue(), we get only "1101" instead. Besides this, there are many other readings not tally.
The hex dump is as below, for your kind references:
TX: 7E A0 4F 00 02 00 23 0F 96 33 A8 E6 E6 00 C0 01 C1 00 07 00 00 63 01 00 FF 02 01 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E9 05 1E FF 00 00 00 FF FE 20 00 09 0C 07 E9 05 1F FF 00 00 00 FF FE 20 00 01 00 B0 4A 7E
RX: 7E A8 8C 0F 00 02 00 23 98 3F F1 E6 E7 00 C4 01 C1 00 01 30 02 0B 02 02 09 0C 07 E9 05 1E FF FF FF FF FF 80 00 FF 04 06 00 00 00 00 05 00 00 00 00 05 00 00 00 10 05 00 00 03 BE 05 00 00 00 00 05 00 00 02 9F 05 00 00 02 9C 05 00 00 02 9C 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B2 05 00 00 00 00 05 00 00 02 99 05 00 00 02 96 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 5E 2F 7E
RX: 7E A8 8C 0F 00 02 00 23 9A 2D D2 03 AB 05 00 00 00 00 05 00 00 02 96 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A8 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 A7 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AD 05 00 00 9A 76 7E
RX: 7E A8 8C 0F 00 02 00 23 9C 1B B7 00 00 05 00 00 02 96 05 00 00 02 93 05 00 00 02 94 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AF 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 AF 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B1 05 00 00 00 00 05 00 00 72 D8 7E
RX: 7E A8 8C 0F 00 02 00 23 9E 09 94 02 97 05 00 00 02 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 97 05 00 00 02 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 98 05 00 00 02 95 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 97 05 00 00 A9 16 7E
RX: 7E A8 8C 0F 00 02 00 23 90 77 7D 02 95 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 AD 05 00 00 00 00 05 00 00 02 97 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AA 05 00 00 00 00 05 00 00 02 96 05 00 00 02 94 05 00 00 02 95 02 0B 00 00 00 00 05 00 00 01 20 05 00 00 00 01 05 00 00 03 16 05 00 00 00 00 05 00 00 02 95 05 00 00 02 93 05 00 00 C2 D7 7E
RX: 7E A8 8C 0F 00 02 00 23 92 65 5E 02 93 02 0B 00 00 00 00 05 00 00 04 DC 05 00 00 00 00 05 00 00 03 18 05 00 00 00 00 05 00 00 02 94 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 06 F4 05 00 00 00 00 05 00 00 03 0B 05 00 00 00 00 05 00 00 02 93 05 00 00 02 90 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 0B 35 05 00 00 00 00 05 00 00 02 F1 05 00 00 00 00 05 00 00 02 92 05 00 00 02 90 05 00 00 02 90 02 0B 00 2B 2A 7E
RX: 7E A8 8C 0F 00 02 00 23 94 53 3B 00 00 00 05 00 00 0E FB 05 00 00 00 00 05 00 00 02 D6 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 11 7A 05 00 00 00 00 05 00 00 02 BB 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 17 52 05 00 00 00 00 05 00 00 02 6E 05 00 00 00 00 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 57 BC 7E
RX: 7E A8 8C 0F 00 02 00 23 96 41 18 00 21 6A 05 00 00 00 00 05 00 00 01 B3 05 00 00 00 00 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 2C 01 05 00 00 00 00 05 00 00 00 BF 05 00 00 00 19 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 30 2F 05 00 00 00 00 05 00 00 00 74 05 00 00 00 54 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 2A B8 05 00 B7 13 7E
RX: 7E A8 8C 0F 00 02 00 23 98 3F F1 00 00 00 05 00 00 00 CE 05 00 00 00 00 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 26 23 05 00 00 00 00 05 00 00 01 47 05 00 00 00 0C 05 00 00 02 91 05 00 00 02 8F 05 00 00 02 8F 02 0B 00 00 00 00 05 00 00 39 7F 05 00 00 00 00 05 00 00 00 00 05 00 00 01 25 05 00 00 02 90 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 35 F2 05 00 00 00 00 05 00 A1 A3 7E
RX: 7E A8 8C 0F 00 02 00 23 9A 2D D2 00 00 00 05 00 00 00 AA 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 32 FF 05 00 00 00 00 05 00 00 00 1B 05 00 00 00 65 05 00 00 02 8E 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 29 35 05 00 00 00 00 05 00 00 00 EC 05 00 00 00 0C 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 2F 17 05 00 00 00 00 05 00 00 00 95 05 00 1D B0 7E
RX: 7E A8 8C 0F 00 02 00 23 9C 1B B7 00 00 7A 05 00 00 02 8F 05 00 00 02 8D 05 00 00 02 8D 02 0B 00 00 00 00 05 00 00 2E 6D 05 00 00 00 00 05 00 00 00 8B 05 00 00 00 57 05 00 00 02 8F 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 32 A8 05 00 00 00 00 05 00 00 00 40 05 00 00 00 8C 05 00 00 02 8F 05 00 00 02 8C 05 00 00 02 8C 02 0B 00 00 00 00 05 00 00 22 FC 05 00 00 00 00 05 00 00 01 75 05 00 00 00 02 05 00 94 23 7E
>>>>>HERE IS THE 12th BLOCK<<<<<
RX: 7E A8 8C 0F 00 02 00 23 9E 09 94 00 02 91 05 00 00 02 8E 05 00 00 02 8E 02 0B 00 00 00 00 05 00 00 19 DA 05 00 00 00 00 05 00 00 02 39 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 0A C8 05 00 00 00 00 05 00 00 02 E8 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 04 4E 05 00 00 00 00 05 00 00 03 07 05 00 00 00 00 05 00 00 02 94 05 00 52 B0 7E
RX: 7E A8 8C 0F 00 02 00 23 90 77 7D 00 02 91 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 02 48 05 00 00 00 00 05 00 00 03 09 05 00 00 00 00 05 00 00 02 94 05 00 00 02 91 05 00 00 02 91 02 0B 00 00 00 00 05 00 00 00 B8 05 00 00 00 05 05 00 00 03 05 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 1C 05 00 00 03 65 05 00 00 00 00 05 00 00 02 95 05 00 00 02 91 05 00 7C C7 7E
RX: 7E A8 8C 0F 00 02 00 23 92 65 5E 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0D 05 00 00 03 A5 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 93 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 A6 05 00 00 00 00 05 00 00 02 95 05 00 00 02 92 05 00 00 02 92 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 AC 05 00 00 00 00 05 00 00 02 98 05 00 00 02 94 05 00 00 02 95 02 0B E1 2D 7E
RX: 7E A8 8C 0F 00 02 00 23 94 53 3B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 AF 05 00 00 00 00 05 00 00 02 99 05 00 00 02 95 05 00 00 02 96 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0F 05 00 00 03 B1 05 00 00 00 00 05 00 00 02 9A 05 00 00 02 96 05 00 00 02 97 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B2 05 00 00 00 00 05 00 00 02 9A 05 00 00 02 97 05 00 00 02 97 02 0B 00 00 00 00 05 9E 64 7E
RX: 7E A0 57 0F 00 02 00 23 96 AD B7 00 00 00 00 05 00 00 00 0F 05 00 00 03 B5 05 00 00 00 00 05 00 00 02 9C 05 00 00 02 98 05 00 00 02 99 02 0B 00 00 00 00 05 00 00 00 00 05 00 00 00 0E 05 00 00 03 B5 05 00 00 00 00 05 00 00 02 9C 05 00 00 02 99 05 00 00 02 9A DA 23 7E
Thanks again.
Jason
Dear Mikko, I think we can…
Dear Mikko,
I think we can close this thread.
We tried to reproduce the problem at site but were unable to. All readings were correct at site. Maybe it was the test meter being faulty, or very different (old) firmware.
Thanks.
Jason
