  2. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd, 21 May, 2025
Gurux DLMS for Android
getting invalid system title in main fragment
though i am selecting general meter settings
now in the 2.0.15 there is an optional fragment called security where the client system title option provided
i need the general meter setting which is getting affected with invalid system title
and open is not happening which was happening in 2.0.14
atuldd
1 month ago
Could you please confirm…
In the billing profile, I am able to retrieve buffered data when selecting "All." However, when I specify a "From" and "To" date range and click "Read," I receive an "Access error: Unknown error."
1 month ago
Hi, Please, create a new…
What system title are you trying to use?
It might be that your meter is not supporting read by entry to this object. It's not usually implemented if amount of rows is small, or there is no date-time column.
  • Thu, 06/19/2025 - 09:33
    Gurux.DLMS.Python 1.0.185
  • Wed, 06/18/2025 - 15:11
    Gurux.DLMS.Python 1.0.184
  • Wed, 06/18/2025 - 10:05
    Gurux.DLMS.Python 1.0.183
  • Wed, 06/18/2025 - 09:06
    GXDLMSDirector 9.0.2506.1801
  • Wed, 06/18/2025 - 08:41
    Gurux.DLMS.Net 9.0.2506.1801
  • object list not get downloaded for firmware upgrade association
  • HLS GMAC L+G 570
  • Unable to read parameter values from Landis+Gyr E550 meter using GXDLMSDirector - NoAccess status
  • data.SetComplete(false); But all data recieved
  • Crash (endless loop)
