  2. Long Reading Ends With "Invalid Frame ..." Error.
Long reading ends with "Invalid frame ..." error.
By abk964, 16 May, 2025
Gurux DLMS for ANSI C
Long seances (hundreds of HDLC packets) ended with "Invalid frame..." errors. Same readings in Director are OK. Different devices.
What can I check by myself?
1 month ago
Hi, If the devices are…
If the devices are different, check that they have the same meter firmware.
You didn't tell what you tried to read, but I believe it's a profile generic.
You can usually ignore the Invalid frame error if you read only a few days from the profile generic at a time. So decrease the number of days that you try to read in one sitting.
abk964
1 month ago
Hi. Found my own mistake…
Hi.
Found my own mistake. Thanks.
  • Thu, 06/19/2025 - 09:33
    Gurux.DLMS.Python 1.0.185
  • Wed, 06/18/2025 - 15:11
    Gurux.DLMS.Python 1.0.184
  • Wed, 06/18/2025 - 10:05
    Gurux.DLMS.Python 1.0.183
  • Wed, 06/18/2025 - 09:06
    GXDLMSDirector 9.0.2506.1801
  • Wed, 06/18/2025 - 08:41
    Gurux.DLMS.Net 9.0.2506.1801
  • object list not get downloaded for firmware upgrade association
  • HLS GMAC L+G 570
  • Unable to read parameter values from Landis+Gyr E550 meter using GXDLMSDirector - NoAccess status
  • data.SetComplete(false); But all data recieved
  • Crash (endless loop)
