  2. Compile Errors DLMS.cpp Server Example On Uncomment DLMS_IGNORE_XML_TRANSLATOR
Compile errors DLMS.cpp server example on uncomment DLMS_IGNORE_XML_TRANSLATOR
By Dmitry, 11 April, 2025
Gurux DLMS for ANSI C++
Hi Mikko!
I uncommented #define DLMS_IGNORE_XML_TRANSLATOR in GXIgnore.h and get many errors about xml. In server example.
invalid use of incomplete type ‘class CGXDLMSTranslatorStructure’
../../../development/src/GXDLMS.cpp:1947:16: error: invalid use of incomplete type ‘class CGXDLMSTranslatorStructure’
1947 | if (xml->GetComments())
‘DLMS_TRANSLATOR_TAGS_BLOCK_NUMBER’ was not declared in this scope
../../../development/src/GXDLMS.cpp:2122:40: error: ‘DLMS_TRANSLATOR_TAGS_BLOCK_NUMBER’ was not declared in this scope
2122 | reply.GetXml()->AppendLine(DLMS_TRANSLATOR_TAGS_BLOCK_NUMBER, "Value", str);
etc.
Thanks!
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
