  2. Porting My App To Linux
Porting my App to Linux
By vasil_gurux, 25 March, 2025
Hi! I have complete working desktop app on win with gurux, and i'm thinkig about porting my app on linux.
Except new UI, what is the main steps, I need to do (or consider to do or do nothing) with Gurux libraries? Sorry, if my question little bit stupud or so) I'm new to such a task and linux.
Thanks in advance).
1 year ago
Hi, You didn't tell what…
You didn't tell what programming language you want to use, but communication client examples are already implemented, e.g., Java, Python, and C#. You need to implement the UI.
vasil_gurux
1 year ago
C# WPF
C# WPF
1 year ago
Hi, You can get the example…
You can get the example client here:
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
I propose that you use MAUI instead of WPF.
vasil_gurux
1 year ago
I have started test project…
I have started test project on Avalonia, and it works fine, except i have some problem with serial ports on my Ubuntu. Need to solve problem with access denied on serial port. As I know NET MAUI not works on Linux but Windows, macOS, iOS, and Android
1 year ago
Hi, You are right. I didn't…
You are right. I didn't remember that Linux is not supported.
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
