  2. Regarding Meter Reconnection Using Gurux .NET In C#
Regarding Meter Reconnection using Gurux .NET in C#
By sirishalv72@gm…, 25 November, 2024
Gurux.Net
Meter is Disconnecting successful but while reconnecting it is throwing exception as
"ServiceError Read exception. Service Unsupported"
the request : {7E A0 25 61 03 52 D9 C0 E6 E7 00 CF 82 00 15 30 00 00 00 03 4A CC A2 70 EA D9 F1 48 D7 C8 F5 6E 50 4C 0A A4 DA FE 7E}
replay : {0E 05 03 02}
while (!Client.GetData(rd, reply, notify))
p.Reply = null;
if (notify.IsComplete && notify.Data.Data != null)
//Handle notify.
if (!notify.IsMoreData)
if (notify.PrimeDc != null)
OnNotification?.Invoke(notify.PrimeDc);
Console.WriteLine(notify.PrimeDc);
else
//Show received push message as XML.
string xml;
GXDLMSTranslator t = new GXDLMSTranslator(TranslatorOutputType.SimpleXml);
t.DataToXml(notify.Data, out xml);
OnNotification?.Invoke(xml);
Console.WriteLine(xml);
notify.Clear();
continue;
while reading data packet
1 year ago
Hi, Did you close the…
Did you close the connection and read the invocation counter? With the most of meters, there can be only one active connection at a time.
Some meters need some time before establishing a new connection. Will it work if you wait e.g. 20 seconds before establishing a new connection?
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • SNRM byte mening
