  2. DLMS OPTICAL METER READING
By Shine, 12 October, 2024
Dear Sir,
I have read the values of the L&T meter using the DMLS director and optical cable. It is working perfectly, and its interface settings are HDLC with MR authentication
After that, I am trying to read the L&T meter using Arduino. In the Arduino development folder, it shows three programs: client, server, and pushListener. From these which programs should I use for meter reading using HDLC with MR authentication
9 months ago
Hi, With client you can read…
With client you can read your meter. Just set the same arguments that you are using with GXDLMSDirector.
  • Wed, 07/09/2025 - 16:41
    Gurux.Serial.Android 2.0.13
  • Wed, 07/09/2025 - 12:07
    gurux.dlms.c 9.0.2507.0901
  • Sat, 07/05/2025 - 15:04
    Gurux.DLMS.Python 1.0.188
  • Tue, 07/01/2025 - 10:09
    Gurux.DLMS.Python 1.0.187
  • Tue, 07/01/2025 - 09:54
    gurux.dlms.c 9.0.2507.0101
  • DLMS communication issue when routing through VPN on Android
  • ESP32-Based Smart Meter Interface via DLMS/COSEM
  • svr_postWrite: args->size Always Zero
  • DLMS over LoraWan in water metering
  • Update High password - any way to cipher new password
