  2. Not Able To Read Profile Generic Data
Not able to read profile generic data
By Bhaumik, 1 October, 2024
I'm using an IS16444 standard meter for testing, and I'm trying to read the Daily Load Profile data (1.0.99.2.0.255) using the Read selector.
Although the meter has 46 entries stored, I'm unable to retrieve them with the Read selector. However, I'm able to get the data using both the Range and All selectors.
Getting "Access Error : Device reports a inconsistent class or object" error prompt.
Please provide your suggestion.
7 months 2 weeks ago
Hi, All meters don't support…
All meters don't support different ways to read profile generic buffer. You need to ask if read-by-entry is implemented for the meter from the meter manufacturer.
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • Tue, 05/13/2025 - 10:00
    Gurux.DLMS.Android 2.0.15
  • Fri, 05/09/2025 - 13:03
    Gurux.DLMS.Python 1.0.181
  • Wed, 05/07/2025 - 16:09
    Gurux.DLMS.Android 2.0.14
  • Long reading ends with "Invalid frame ..." error.
  • Push listener example how it works + tcp stream issue
  • Problem with reading energymeter Star DTS27 via GXDLMSDirector
  • Receiver Ready Test Failed
  • Combining several meters' profile generic data into one
