By eduard.ch, 30 September, 2024 Forums DLMSDirector Hello! Can you add any button that allows the user to update the arbitrator parameters? Or can you explain how to set new values if this feature is already added? Thanks in advance Hi, You can change the… Hi, You can change the parameters if you modify them and then write it to the meter. I notest that the permissions and weightings table are missing from the UI. They will be added to the next version. BR, Mikko I'll look forward to it… I'll look forward to it. Thanks! Hello, as far as I see there… Hello, as far as I see there is still no UI ability to change permissions and weightings table values for Arbitrator class? BR, Andrew Log in or register to post comments
BR, Andrew
