  2. Exception Response: Instance ID 0.0.40.0.0.255
By girija, 21 September, 2024
Gurux.Serial
Hello Sir,
Meter is responds with ExceptionResponse while reading logical_name of 0.0.40.0.0.FF in NO_SECURITY: Class ID-1. The report suggests as follow.
Errors
Invalid DLMS version: 0
AssociationLogicalName 0.0.40.0.0.255 Get 5 is invalid.
Expected:
<GetResponse>
<GetResponseNormal>
<InvokeIdAndPriority Value="*" />
<Result>
<Data>
<Structure Qty="6">
<BitString Value="*" />
<UInt16 Value="*" />
<UInt8 Value="6" />
<Int8 Value="*" />
<OctetString Value="*" />
</Structure>
</Data>
</Result>
</GetResponseNormal>
</GetResponse>
Actual:
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<Structure Qty="06" >
<BitString Value="000000000000000000010000" />
<UInt16 Value="0400" />
<UInt8 Value="00" />
<Int8 Value="00" />
<OctetString Value="" />
</Structure>
</Data>
</Result>
</GetResponse>
What could be the reason ?
Where should I make changes?
Thank you.
Girija
8 months 4 weeks ago
Hi, You are returning zero…
You are returning zero as a DLMS version when it should be six.
girija
8 months 3 weeks ago
Sir, I have changed the DLMS…
Sir,
I have changed the DLMS-Version from 0 to 6 as you suggested. Now the error regarding the version number is removed in the test-report. All the other values are still the same except for <UInt8 Value="00" /> is now replaced by <UInt8 Value="06" /> as mentioned above.
What does it mean by 'Get 5 invalid' ?
Girija
Hi, Can you add request and…
Can you add request and response hex values so I can check what might cause this?
Mkko
girija
8 months 2 weeks ago
I understood that in my…
I understood that in my previous question, 'Get 5' represents an Attribute 5.
Here is the Request-Response Hex values of Association Logical Name : Attribute 05.
125: 7E A0 19 03 41 BA 7A B5 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 05 00 99 1E 7E
<HDLC len="18" >
<TargetAddress Value="1" />
<SourceAddress Value="20" />
<FrameType Value="BA" />
<PDU>
<GetRequest>
<GetRequestNormal>
<!-- Priority: High, ServiceClass: Confirmed, Invoke ID: 1 -->
<AttributeDescriptor>
<!-- AssociationLogicalName -->
<ClassId Value="000F" />
<!-- 0.0.40.0.0.255 -->
<InstanceId Value="0000280000FF" />
<AttributeId Value="05" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
</PDU>
</HDLC>
126: 7E A0 23 41 03 DA 38 80 E6 E7 00 C4 01 C1 00 02 06 04 18 00 10 14 12 04 00 12 04 00 11 06 0F 00 09 00 34 DB 7E
<HDLC len="22" >
<TargetAddress Value="20" />
<SourceAddress Value="1" />
<FrameType Value="DA" />
<PDU>
<GetResponse>
<GetResponseNormal>
<Result>
<Data>
<BitString Value="000000000001000000010100" />
<Int8 Value="00" />
</Structure>
</Data>
</Result>
</GetResponse>
</PDU>
</HDLC>
I also noticed a note states, "//Protocol version must be 100001". Is the error regarding to the version again? Although I have changed the version number,
settings->base.dlmsVersionNumber = 6;
Also, by mistake I mentioned class ID-1 in my very first question, but its actually a Class ID-15.
Girija
Hi, You need to ask the…
You need to ask the questions from the stack (library) vendor. There are multiple arguments in DLMS and it's hard to say what might be the reason because I don't have the source code.
  • Thu, 06/19/2025 - 09:33
    Gurux.DLMS.Python 1.0.185
  • Wed, 06/18/2025 - 15:11
    Gurux.DLMS.Python 1.0.184
  • Wed, 06/18/2025 - 10:05
    Gurux.DLMS.Python 1.0.183
  • Wed, 06/18/2025 - 09:06
    GXDLMSDirector 9.0.2506.1801
  • Wed, 06/18/2025 - 08:41
    Gurux.DLMS.Net 9.0.2506.1801
  • HLS GMAC L+G 570
  • Unable to read parameter values from Landis+Gyr E550 meter using GXDLMSDirector - NoAccess status
  • data.SetComplete(false); But all data recieved
  • Crash (endless loop)
  • Server is not able to download object list with maxPduSize 64 or 128 (or anything below 156-bytes PDU size)
