  2. Energy Meter Data Reading Using Node Red DLMS
Energy Meter Data Reading Using Node red DLMS
By vmahenk2016, 15 September, 2024
Dear Sir,
We have a requirement of Read data DLMS meter & need to send this data on cloud using customized MQTT topics.
Is it possible to use node red.??
We require premium solutions Can you support us.??
mail id:- [Email address removed,]
Thanks & Regards,
Mahenk Vasani
Pacemaker Solutions.
1 year 1 month ago
Hi, Node RED is not…
Node RED is not supported at the moment so yo need to implement it e.g. with java.
You need to implement DLMS client that reads the meter and then sends read values as MQTT topics.
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • Thu, 10/16/2025 - 09:59
    gurux.dlms.java 4.0.83
  • Wed, 10/08/2025 - 10:21
    gurux.dlms.c 9.0.2510.0801
  • Fri, 09/26/2025 - 10:02
    gurux.dlms.cpp 9.0.2509.2601
  • Fri, 09/26/2025 - 09:45
    gurux.dlms.c 9.0.2509.2601
  • How to get/convert user readable format data from readRowsByRange
  • Insufficient memory to continue the execution of the program.
  • The client instance code failed to connect to the electricity meter for authentication
  • Unable to Release Request when closing connection with meter.
  • Failed to receive reply from the device in given time.
