  2. Teltonika TRB245 IOT Gateway Connectivity With Secure Premier 300 DLMS Meter
Teltonika TRB245 IOT Gateway connectivity with Secure Premier 300 DLMS Meter
Profile picture for user rooftopurja
By rooftopurja, 27 July, 2024
We have connected TRB245 model gateway - RS232 port to the Meter Com Port - Secure Premier 300 DLMS Meter with RJ11 cable - color coding given by manufacturer. TRB245 - DLMS client package is downloaded and being configured to establish communication with the meter but it is failing repeatedly.
Please explain how to establish connection between TRB245 and DLMS Meter. In the TRB245 - DLMS configuration page - default setting entered are physical server id 1, client server address 16, authentication none
10 months 2 weeks ago
Hi, You need to ask this…
You need to ask this from Teltonica.
It might be that the baud-rate of the serial port is different than the gateway expects.
Your meter might also use other server address than one.
  • Wed, 06/04/2025 - 13:35
    gurux.dlms.c 9.0.2506.0401
  • Fri, 05/30/2025 - 08:30
    gurux.dlms.c 9.0.2505.3001
  • Tue, 05/27/2025 - 08:10
    Gurux.Serial.Android 2.0.12
  • Mon, 05/26/2025 - 08:39
    gurux.dlms.c 9.0.2505.2601
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Create gateway protocol in c
  • Error while reading event log object
  • GXDLMS Simulator – AssociationLogicalName Not Listed
  • Failed to read meter through raspberry pi 5 and probe
  • Protocol Version in AARQ Packet
