  2. What Is The Seqence of Function We Should Call To Read Assoiation and Profile Generic Data
What is the seqence of function we should call to read Assoiation and profile generic data
By satishjyoti1998, 16 July, 2024
Gurux.Serial
Please let us know in which sequence I call function to read association and profile generic data. Please let us know what code we should write where to save association and profile generic data.
Regards
Satish
10 months 3 weeks ago
Hi, You can use client…
You can use client example to read the association view and all the objects from the association view. The association view is saved to the file if you add -O argument.
Because I don't know what programming language you are using I can't give the exact URL to the example, but you can find them here:
https://github.com/gurux
  • Wed, 06/04/2025 - 13:35
    gurux.dlms.c 9.0.2506.0401
  • Fri, 05/30/2025 - 08:30
    gurux.dlms.c 9.0.2505.3001
  • Tue, 05/27/2025 - 08:10
    Gurux.Serial.Android 2.0.12
  • Mon, 05/26/2025 - 08:39
    gurux.dlms.c 9.0.2505.2601
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Create gateway protocol in c
  • Error while reading event log object
  • GXDLMS Simulator – AssociationLogicalName Not Listed
  • Failed to read meter through raspberry pi 5 and probe
  • Protocol Version in AARQ Packet
