By Thangalakshmi, 5 July, 2024 Forums Gurux.Serial windows 10 its running fine but after windows 11 installation not able to read profiles gurux_dlms version: 1.0.155… i tried but its disconnected. But same script its running Windows 10. gurux_dlms version: 1.0.155 gurux_net version: 1.0.21 gurux_serial version: 1.0.20 Authentication: 2 ClientAddress: 0x30 ServerAddress: 0x1 Standard: 1 Security: 48 System title: 71 77 65 72 74 79 75 69 Authentication key: 41 45 57 5F 50 57 52 5F 41 4B 5F 45 4B 5F 32 34 Block cipher key: 41 45 57 5F 50 57 52 5F 41 4B 5F 45 4B 5F 32 34 DisconnectRequest Ended. Press any key to continue. Kindly help me. Hello Mikko, Help me Hello Mikko, Help me Hi, One of your settings is… Hi, One of your settings is different, or there are new rows on the meter that cause this. There is nothing that might affect for profile generic reading. Check if you can read the profile generic with GXDLMSDirector. BR, Mikko After window 11 installation… After window 11 installation I am facing GXDLMSDirector also. I checked all the keys but its showing error like: connection is permanently rejected. No reason is given Image Hi Miko, pls help me Hi Miko, help me Hi, One of your settings is… Hi, One of your settings is different than the meter expects. Can you connect with authentication level None? BR, Mikko Hi Mikko, Yes, I tried but… Hi Mikko, Yes, I tried but same thing happen.Its showing error like: connection is permanently rejected. No reason is given Hi, You must use the client… Hi, You must use the client address 0x10 when connecting without an authentication level. Are you using it? If you are, try to reboot the meter. BR, Mikko Hello Mikko, Tried but still… Hello Mikko, Tried but still same issue. Hi, Did you change the… Hi, Did you change the client address to 10 when connecting without authentication? BR, Mikko Hi Mikko, Yes, Without… Hi Mikko, Yes, Without authentication its working but US(Utility Setting) mode its not working. Hi, Have you set the… Hi, Have you set the authentication key and block cipher key? BR, Mikko Log in or register to post comments
Authentication: 2
ClientAddress: 0x30
Standard: 1
Security: 48
Kindly help me.
Hi Miko, help me
Hello Mikko,
