  2. HLS7 / ECDSA Support
HLS7 / ECDSA support
By jan.kolar, 17 May, 2024
do I need to enable transfer of client / server certificates in AARQ / AARE packets or is it done automatically by Gurux.DLMS.cpp library ?
1 year 1 month ago
Hi, Currently, the ECDSA…
Currently, the ECDSA Certificate is not sent as part of AARQ/AARE. The client certificate must be import and the server certificate export using the security setup object.
I know that there is now a meter that is using only this approach so I added it to the worklist and it's coming for the next release.
  • Wed, 07/09/2025 - 16:41
    Gurux.Serial.Android 2.0.13
  • Wed, 07/09/2025 - 12:07
    gurux.dlms.c 9.0.2507.0901
  • Sat, 07/05/2025 - 15:04
    Gurux.DLMS.Python 1.0.188
  • Tue, 07/01/2025 - 10:09
    Gurux.DLMS.Python 1.0.187
  • Tue, 07/01/2025 - 09:54
    gurux.dlms.c 9.0.2507.0101
  • DLMS communication issue when routing through VPN on Android
  • ESP32-Based Smart Meter Interface via DLMS/COSEM
  • svr_postWrite: args->size Always Zero
  • DLMS over LoraWan in water metering
  • Update High password - any way to cipher new password
