  2. Gurux Serial Android (java) Not Have Baudrate 460800
Gurux Serial Android (java) not have Baudrate 460800
By Pavel, 17 April, 2024
Gurux.Serial
Good afternoon, sir.
You can add to gurux.io.BaudRate (Android) value 460800?
Or tell me how i can set this value.
Baudrate.java have max 38400 value.
public enum BaudRate {
* 38,400 baud.
BAUD_RATE_38400 (38400),
* 19,200 baud.
BAUD_RATE_19200(19200),
1 year 1 month ago
Hello, I have to say that…
I have to say that you have a very fast connection. We'll add support for the higher values today.
1 year 1 month ago
Hi, Version 2.0.3 from gurux…
Version 2.0.3 from gurux.serial.android is released. Note that I don't know what is the maximum baud rate that your USB to serial port converter supports.
Pavel Saburov
1 year 1 month ago
Thank you. All work
Thank you. All work
  • Wed, 06/04/2025 - 13:35
    gurux.dlms.c 9.0.2506.0401
  • Fri, 05/30/2025 - 08:30
    gurux.dlms.c 9.0.2505.3001
  • Tue, 05/27/2025 - 08:10
    Gurux.Serial.Android 2.0.12
  • Mon, 05/26/2025 - 08:39
    gurux.dlms.c 9.0.2505.2601
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Error while reading event log object
  • GXDLMS Simulator – AssociationLogicalName Not Listed
  • Failed to read meter through raspberry pi 5 and probe
  • Protocol Version in AARQ Packet
  • Problem with reading energymeter iskraemeco MT880
