Hi, Mr Kurumi.
I try to connect to Inhemeter meter, but I got this message:
ServiceError Initiate Error exception. Initiate IncompatibleConformance.
GXDLMSDirector 9.0.2302.2001
Log created 15:46:22
15:46:31 Initializing serial connection.
15:46:32 IEC Sending:/?!<CR><LF>
15:46:42 Failed to receive reply from the device in given time.
15:46:43 HDLC received: /IHM5\2Inhe Meter<CR><LF>
15:46:43 BaudRate is : 9600
15:46:43 Moving to mode E.
06 32 35 32 0D 0A
15:46:46 Send SNRM request.
7E A0 07 03 03 93 8C 11 7E
15:46:46
7E A0 20 03 03 73 F0 2E 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
15:46:46 Parsing UA reply succeeded.
15:46:46 Send AARQ request.
7E A0 44 03 03 10 65 94 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 92 4A 7E
15:46:47
7E A0 2D 03 03 30 E0 D5 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 06 04 04 0E 01 06 02 F7 43 7E
15:46:47 Disconnect request
15:46:52 Failed to receive reply from the device in given time.
Gurux.DLMS.GXDLMSConfirmedServiceError: ServiceError Initiate Error exception. Initiate IncompatibleConformance
à Gurux.DLMS.Internal.GXAPDU.ParsePDU2(GXDLMSSettings settings, GXICipher cipher, GXByteBuffer buff, GXDLMSTranslatorStructure xml)
à Gurux.DLMS.Internal.GXAPDU.ParsePDU(GXDLMSSettings settings, GXICipher cipher, GXByteBuffer buff, GXDLMSTranslatorStructure xml)
à Gurux.DLMS.GXDLMSClient.ParseAAREResponse(GXByteBuffer reply)
à GXDLMSDirector.GXDLMSCommunicator.ParseAAREResponse(GXByteBuffer data)
à GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force)
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
Hi, Try to remove…
Try to remove DeltaValueEncoding from the supported services tab. It's causing problems with some meters.
Thank you for your response…
Thank you for your response.
Problem solved, the server address was wrong.
Best regards.
Hi, Thank you for letting me…
Thank you for letting me know about this. I can say that this is the most common reason why communication fails.
