  2. 0 Is Not a Valid ExceptionServiceError
0 is not a valid ExceptionServiceError
By wadhwahitesh, 12 July, 2023
Gurux.Terminal
When I give command (py main.py -h 2401:4900:4024:01e4::2 -p 4059 -i WRAPPER -c 32 -a Low -P XXXX -C AuthenticationEncryption -T 49484D3132333435 -A XXXX -B XXXX -v 0.0.43.1.2.255 -d India -t Verbose -g "0.0.96.1.0.255:2;0.0.96.1.0.255:1") on the terminal, I get the error - 0 is not a valid ExceptionServiceError
gurux_dlms version: 1.0.143
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
Authentication: 1
ClientAddress: 0x20
Standard: 1
Security: 48
System title: 49 48 4D 31 32 33 34 35
Authentication key: 31 32 33 34 35 36 37 38 31 32 33 34 35 36 37 38
Block cipher key: 31 32 33 34 35 36 37 38 31 32 33 34 35 36 37 38
TX: 13:04:20 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF
RX: 13:04:21 00 01 00 01 00 10 00 2B 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 04 34 00 07
TX: 13:04:21 00 01 00 10 00 01 00 0D C0 01 C1 00 01 00 00 2B 01 02 FF 02 00
RX: 13:04:22 00 01 00 01 00 10 00 09 C4 01 C1 00 06 06 A2 C3 90
Invocation counter: 111330193
TX: 13:04:22 00 01 00 10 00 01 00 09 62 03 80 01 00 03 80 01 00
RX: 13:04:23 00 01 00 01 00 10 00 17 63 15 80 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 04 34 00 07
TX: 13:04:23 00 01 00 20 00 01 00 57 60 55 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 31 32 33 34 35 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 23 04 21 21 1F 30 06 A2 C3 91 54 38 D7 93 EB 13 5F 25 77 7D 1B 8C 30 93 22 09 B3 9B 9F AD 0D 20 15 0F D8 B5
RX: 13:04:24 00 01 00 01 00 20 00 4A 61 48 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 00 A4 0A 04 08 49 48 4D 01 70 99 5B 21 BE 23 04 21 28 1F 30 00 00 3F 46 3F 0D 61 65 EA D1 D8 BB 37 81 B0 15 F7 AC B7 D4 E8 B6 A5 A3 44 1B FE A3 DF A2
TX: 13:04:24 00 01 00 20 00 01 00 20 C8 1E 30 06 A2 C3 91 95 39 16 93 E2 4C 40 09 77 3D FA D3 CF EE 8A 6C 4E 64 49 6D 69 E6 89 86 BF
RX: 13:04:25 00 01 00 01 00 20 00 03 D8 01 00
TX: 13:04:25 00 01 00 20 00 01 00 09 62 03 80 01 00 03 80 01 00
RX: 13:04:26 00 01 00 01 00 20 00 05 63 03 80 01 01
2 years ago
Hi, This meter returns an…
This meter returns an invalid error code not defined by DLMS standards. It would be best to ask the meter vendor what this error means and how to avoid it.
wadhwahitesh
2 years ago
Hi, But when I use the same…
But when I use the same settings to connect through GXDLMSDirector, it connects and shows the meter number. See attached screenshot.
Regards
Hitesh
1 year 12 months ago
Hi, The meter returns an…
The meter returns an error when you try to read the association view. Can you read the association view with GXDLMSDirector when you connect with Low authentication?
wadhwahitesh
Hi Miko, Yes, I can read the…
Hi Miko,
Yes, I can read the association view from the GXDLMSDirector. Take a look at the attached screenshot of MR.
Regards
Hitesh
  • Wed, 07/09/2025 - 16:41
    Gurux.Serial.Android 2.0.13
  • Wed, 07/09/2025 - 12:07
    gurux.dlms.c 9.0.2507.0901
  • Sat, 07/05/2025 - 15:04
    Gurux.DLMS.Python 1.0.188
  • Tue, 07/01/2025 - 10:09
    Gurux.DLMS.Python 1.0.187
  • Tue, 07/01/2025 - 09:54
    gurux.dlms.c 9.0.2507.0101
  • DLMS communication issue when routing through VPN on Android
  • ESP32-Based Smart Meter Interface via DLMS/COSEM
  • svr_postWrite: args->size Always Zero
  • DLMS over LoraWan in water metering
  • Update High password - any way to cipher new password
