  3. Error When Opening a Connection
Error when opening a connection
By kobe, 22 August, 2017
Gurux.SMS
Today I tried to find some code to control a sms modem of schneider electric, with at commands and c#. i tried to use this library but everytime I open the connection, the error "Pin is needed" is shown.
I had a look in the source code and it seems to be a problem in the code sheet GXSMS.cs, in the open method the program sends the AT command "AT+CPIN?\r" at line 1196. Then the modem replys with "+CPIN: READY", the code also waits to get this command but there is a problem there. The SendCommand method seems unable to give this as a reply, because there is no OK in this reply.
Is my modem not following an agreement, that states an OK is needed?
Is this maybe a bug in the code?
This seems critical to me, do other modems give a different reply?
Can someone have a look at this?
At the moment I have changed the code so the READY command is accepted without OK.
Kind regards.
8 years 3 months ago
We tested this with few modems. All are returning OK at the end:
AT+CPIN?
+CPIN: READY
OK
Are you receiving \r\n after READY?
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
  • SNRM byte mening
  • Warisara
  • ajumail
  • 智发
  • Elie_George
  • henry@mactron.co.za
