  2. How To Prepare Profile General For Writing?
How to prepare Profile General for writing?
By george@n, 31 August, 2025
Gurux DLMS for ANSI C
Using the API's provided, how to prepare the Profile General to look like in your example below? What need to be done before calling cl_write() to prepare array and structures.
https://www.gurux.fi/sites/default/files/issues/Profile%20Generic%20att…
3 months 1 week ago
Hi, You want to write…
You want to write capture objects for the profile generic object.
set the capture objects like this:
gxTarget* capture;
//Add clock object.
capture = (gxTarget*)malloc(sizeof(gxTarget));
capture->attributeIndex = 2;
capture->dataIndex = 0;
arr_push(&pg.captureObjects, key_init(&clock1, capture))
Then write attribute #3.
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
  • SNRM byte mening
