  2. DLMS Python Client : Unknown Object
DLMS python client : unknown object
By Harshi_554, 9 June, 2025
Hii,
I'm running DLMS python client code. Why the below prints appears on the screen? Does it cause error while saving the output to xml file?
Unknown object : 77 0.0.24.9.0.255
Unknown object : 76 0.0.24.8.0.255
Unknown object : 123 0.0.18.0.0.255
Unknown object : 151 0.0.25.11.0.255
10 months ago
Hi, M-Bus diagnostic, M-Bus…
M-Bus diagnostic, M-Bus port setup, array manager, and LTE monitoring are not implemented in Python because customers haven't requested them.
You can ignore this warning if you don't need those objects.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
