  2. If The Latest Software Not Support Wi-SUN(such As Class_id = 95, 96,97,98)
if the Latest software not support Wi-SUN(such as class_id = 95, 96,97,98)
By holley-cgd, 29 April, 2025
I Downloaded the latest DLMSDirector, connect and read Association is OK. But the resault is not include the "Wi-SUN setup (class_id = 95, version 0)", In fact, the data frame contains this data item. Some data frames are intercepted as follows:
12 00 5F 11 00 09 06 00 00 22 00 00 FF 02 02
01 0F
02 03 0F 01 16 01 00
02 03 0F 02 16 03 00
02 03 0F 03 16 03 00
02 03 0F 04 16 03 00
02 03 0F 05 16 03 00
02 03 0F 06 16 03 00
02 03 0F 07 16 03 00
02 03 0F 08 16 03 00
02 03 0F 09 16 03 00
02 03 0F 0A 16 03 00
02 03 0F 0B 16 03 00
02 03 0F 0C 16 03 00
02 03 0F 0D 16 00 00
02 03 0F 0E 16 03 00
02 03 0F 0F 16 03 00
9 months 2 weeks ago
Hi, Wi-SUN support has not…
Wi-SUN support has not been implemented yet, as there hasn't been customer demand so far. It is planned for the future, but the timeline is still uncertain.
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Python GXDLMSTranslator
  • Issue with KWH Value Reading Using Gurux DLMS Library.
  • CEWE Prometer 100
