  2. Sagemcom DlmsDirector Settings
Sagemcom DlmsDirector settings
By ducatilm, 20 March, 2025
Hi , I try to connect with DlmsDirector on Sagemcom XT211 meter . I choose the manufacturer from the drop down menu (sagemcom energy & telecom) and when I try to make connection I receive that error "manufacturer type does not much. Manufacturer is SAG and should be SET".
Is possible to fix the issue with software??
2 months ago
Hi, It seems that Sagemcom…
It seems that Sagemcom Energy & Telecom has reserved two flag IDs with the same name.
Restart GXDLMSDirecor and select "New Manufacturer Settings Available" from the top menu.
Sagemcom Energy & Telecom (SAG) is added to manufacturers.
Select it and you should be able to read your meter.
  • Tue, 05/20/2025 - 08:40
    gurux.dlms.c 9.0.2505.2001
  • Mon, 05/19/2025 - 10:19
    gurux.net.java 1.0.30
  • Mon, 05/19/2025 - 10:00
    gurux.dlms.c 9.0.2505.1901
  • Thu, 05/15/2025 - 16:26
    gurux.dlms.c 9.0.2505.1501
  • Wed, 05/14/2025 - 08:30
    gurux.dlms.c 9.0.2505.1401
  • Reading all "Data" object type parameter together
  • com_read getting failed for billing profile and instantaneous profile
  • Simulator connection closed
  • Regarding the dlms android project
  • Issue with "ServiceError Initiate Error exception. Service UNSUPPORTED"
