  2. Tip To Use Collected Data In Other Applications
Tip to use collected data in other applications
By VegardS, 17 March, 2025
Gurux.DLMS.AMI
First of thank you for providing these excellent tools open-source!
I have successfully running the AMI4 in docker and connected it to MySQL (MariaDB) and a meter (Cewe Prometer 100). Imported the Device Template form GXDLMSDirector with some COSEM-objects.
Running fine!
But I have a "missing link" in my knowledge to get access to the data from other applications.
I thought that I could query the SQL database but i seams hard. And it also seams difficult thought the REST also.
I wish to retrieve the data from a ProfileGeneric Object with time and data. Preferably with option of time-range.
Could you give me a tip on the way?
Below is a snippet by inspecting the COSEM object. I have already run the read command, collection approx 7 month of 15 minutes interval data
1.0.99.1.0.255
LiFo
0.0.1.0.0.255
Ch. 0 Clock object #1
1.0.1.29.0.255
Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 5
1.0.2.29.0.255
Ch. 0 Sum Li Active power- (QII+QIII) Time integral 5
1.0.129.29.0.255
Man. specific
1.0.130.29.0.255
Man. specific
1.0.5.29.0.255
Ch. 0 Sum Li Reactive power QI Time integral 5
1.0.8.29.0.255
Ch. 0 Sum Li Reactive power QIV Time integral 5
1.0.6.29.0.255
Ch. 0 Sum Li Reactive power QII Time integral 5
1.0.7.29.0.255
Ch. 0 Sum Li Reactive power QIII Time integral 5
1.0.9.29.0.255
Ch. 0 Sum Li Apparent power+ (QI+QIV) Time integral 5
1.0.10.29.0.255
Ch. 0 Sum Li Apparent power- (QII+QIII) Time integral 5
1.0.96.5.4.255
Ch. 0 Internal operating status (status word #4)
12/4/2023 12:15:00.000 AM
0
0
0
0
0
0
0
0
0
0
1
1 year ago
Hi, You can use the Swagger…
You can use the Swagger to show the REST interface. The address is something like:
https://localhost:8001/swagger
You can read the value using api/Value/List API.
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • Tue, 04/07/2026 - 14:50
    gurux.dlms.java 4.0.91
  • Tue, 04/07/2026 - 14:00
    Gurux.DLMS.Net 9.0.2604.0701
  • Mon, 03/30/2026 - 15:39
    gurux.dlms.c 9.0.2603.3001
