  2. How To Connect Smart Enregy Meter Using RS485
How to connect smart enregy meter using RS485
By rxt1008, 8 January, 2025
I need to connect smart meter with DLMS director,using rs485 protocol, so I am trying but its not working ,any link how to get data ,in public mode using rs485
11 months ago
Hi, Several settings can…
Several settings can cause the RS-485 connection to fail.
At first, try to connect with an optical probe to your meter and read the used serial baud rate from IEC HDLC setup object.
Then read the device address and use it as a server address.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSIecHdlcSetup
  • Wed, 12/10/2025 - 08:45
    gurux.dlms.java 4.0.85
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • GXTIME Conversion Issue
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
  • SNRM byte mening
