Hi, I am new to DLMS. I would like to know the (minimum, average and maximum) time (milliseconds or seconds) to read 5 parameters from a typical smart meter over DLMS using a laptop or PC connected using an optical to USB cable.
It's not possible to say because it depends on the manufacturer and what you try to read. You must also establish the connection before reading and close the connection after read.
In general speaking, I would say that it takes about one second.
Hi, It's not possible to say…
Thank you for your reply. I…
I will consider ~1 second time to exchange frames for read 5 parameters.
