  2. L & T ER300P Communication Issue
L & T ER300P communication issue
By webhook, 12 December, 2024
I am attempting to establish communication between the L&T ER300P Indian meter and the GURUx software. The communication works seamlessly using the optical cable. However, when I switch to the RJ11 port, utilizing an RJ11-to-DB9 converter, I am unable to establish communication.
I would appreciate any guidance or assistance in resolving this issue.
12 months ago
Hi, Make sure that your…
Make sure that your Interface is HDLC. You need to check what baud rate the meter uses. That can be anything, but it should be on the meter documentation.
If you don't have the documentation, you can use GXDLMSDirector HDLC address resolver to find the correct baudrate. This video might be helpful.
https://youtu.be/BeaWKmyMwuE
webhook
12 months ago
I believe there are no…
I believe there are no problems with configurations, addresses, or baudrates because I already have success with optical cable.
12 months ago
Hi, It tells nothing from RS…
It tells nothing from RS-232 if you can connect with an optical probe. You use a different communication channel when you are using optical or RS-232.
The optical cable and RS-232 can be configured to use different baud rates.
webhook
12 months ago
I have tried all baudrates…
I have tried all baudrates with RS232 but nothing happen I am using RJ11 to DB9 cable, then RS232 to TTL converter and then USB to ttl for PC
12 months ago
Hi, Get the direct RJ11 to…
Get the direct RJ11 to USB cable. I believe it will solve your problem.
webhook
12 months ago
I have purchased RJ11 to USB…
I have purchased RJ11 to USB cable and check for baudrate using GXDLMSDirector HDLC address resolver, still no success.
It failed for every baudrates
12 months ago
Hi, I made a fast check from…
I made a fast check from the test devices and found Aurora and a couple of others from Larsen&Tourbo, but didn't find ER300P, so I can't test this.
I believe you should ask for the correct serial port settings from the meter vendor.
webhook
12 months ago
Okay Thank you
Okay Thank you
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
  • SNRM byte mening
