  2. I Required Default Password
i required default password
By sekar, 27 November, 2024
Gurux DLMS for ANSI C
i am using GurxDLMSServerExample2 , i want read data from server using GXDLMSDirector (Note: Indian standard, Authendication-MR, serial port)what is the
default password and how to change password in server
7 months 3 weeks ago
Hi, The default password is …
The default password is "Gurux".
You can change the password if you select "Association logical name" and "General". Then click "Update Low password".
sekar
if use password Gurux is 15…
15:45:55 Send SNRM request.
TX: 7E A0 07 03 41 93 5A 64 7E
15:46:00 Data send failed. Try to resend 1/3
in follwing details i give in GXDLMSDirector
Manufacturer: Indian Standard
Interface: HDLC
Authentication: MR
Password: 1234567890123456 (i need this default password and change password procedure)
wait time: 00.00.05
Address type :default
Logical Server: 0
Media :serial
client Address: 20
resend count :3
Physical Server: 1
in above setting i need password for default and i need to change password
i am using server is GuruxDLMSServerExample2
sekar
7E A0 3E 03 25 32 7D 67 E6…
7E A0 3E 03 25 32 7D 67 E6 E6 00 CB 30 30 00 00 00 01 73 F8 50 D3 DA CD 18 95 2C 18 02 BC 29 F0 F7 50 B8 7C 82 EF 1C 96 22 4A A8 7D 2D 7D 7F 2A 5F 0B 2D 50 F0 81 16 16 EE BD E8 65 35 05 81 7E
7E A0 24 25 03 52 75 B9 E6 E7 00 CF 16 30 00 00 00 13 35 26 09 6F 98 F3 9F 3A 5C 5A 0F 8D 4C B3 AA 25 F6 54 F4 7E
above command getting device report read-write denied
Hi, The example uses client…
The example uses client address 0x11 for Low-level authentication.
You need to use it or change it for the code.
sekar
above command getting error message
device report read-write denied can you explain what could be the problem
7 months 2 weeks ago
Hi, You try to connect with…
You try to connect with a deciphered connection and this association doesn't use it.
If you want to try with a ciphered connection, change the client address to 1 and authentication to GMAC
  • Wed, 07/09/2025 - 16:41
    Gurux.Serial.Android 2.0.13
  • Wed, 07/09/2025 - 12:07
    gurux.dlms.c 9.0.2507.0901
  • Sat, 07/05/2025 - 15:04
    Gurux.DLMS.Python 1.0.188
  • Tue, 07/01/2025 - 10:09
    Gurux.DLMS.Python 1.0.187
  • Tue, 07/01/2025 - 09:54
    gurux.dlms.c 9.0.2507.0101
  • DLMS communication issue when routing through VPN on Android
  • ESP32-Based Smart Meter Interface via DLMS/COSEM
  • svr_postWrite: args->size Always Zero
  • DLMS over LoraWan in water metering
  • Update High password - any way to cipher new password
