I'm using an IS16444 standard meter for testing, and I'm trying to read the Daily Load Profile data (1.0.99.2.0.255) using the Read selector.
Although the meter has 46 entries stored, I'm unable to retrieve them with the Read selector. However, I'm able to get the data using both the Range and All selectors.
Getting "Access Error : Device reports a inconsistent class or object" error prompt.
Please provide your suggestion.
Hi, All meters don't support…
All meters don't support different ways to read profile generic buffer. You need to ask if read-by-entry is implemented for the meter from the meter manufacturer.
