  2. Agent In Docker
Agent in docker
By thiesens, 30 September, 2024
Gurux.DLMS.AMI
Hi Gurux.
Will you be adding a version of the agent, to run in docker?
/Henrik
thiesens
9 months 1 week ago
was thinking: Add params to…
was thinking:
Add params to class:
static string serverName = Environment.GetEnvironmentVariable("GURUX_SERVER") ?? "https://localhost:8001";
static string hostName = Environment.GetEnvironmentVariable("GURUX_HOST") ?? System.Net.Dns.GetHostName();
static string token = Environment.GetEnvironmentVariable("GURUX_TOKEN");
Change the RegisterAgent:
public static async Task RegisterAgent(
IServiceCollection services,
AutoResetEvent newVersion,
IGXAgentWorker worker,
AgentOptions options)
string name = hostName ?? System.Net.Dns.GetHostName();
if (string.IsNullOrEmpty(token))
Console.WriteLine("Running on host. Collecting params");
// string name = System.Net.Dns.GetHostName();
Console.WriteLine("Welcome to use Gurux.DLMS.AMI.");
Console.WriteLine(string.Format("Gurux.DLMS.AMI address: [{0}]", options.Address));
string? tmp = Console.ReadLine();
if (!string.IsNullOrEmpty(tmp))
options.Address = tmp;
Console.WriteLine(string.Format("Enter agent name: [{0}]", name));
name = tmp;
Console.WriteLine("Enter Personal Access Token:");
options.Token = Console.ReadLine();
if (options.Token == null || options.Token.Length != 64)
throw new ArgumentException("Invalid token.");
else
Console.WriteLine("Running in a container.");
options.Address = serverName;
name = hostName;
options.Token = token;
worker.Init(services, options, newVersion);
options.Id = await worker.AddAgentAsync(name);
if (options.Id == Guid.Empty)
throw new ArgumentException("Invalid agent Id.");
File.WriteAllText(settingsFile, JsonSerializer.Serialize(options));
Console.WriteLine("Connection succeeded.");
Add a dockerfile, and run it with the 3 env variables.
9 months 1 week ago
Hi Henrik, Yes, this is…
Hi Henrik,
Yes, this is possible. The new Gurux.DLMS.AMI tests start next week. I'll check if it is possible to add this before the next version is released, but it's coming latest with the new version.
thiesens
9 months 1 week ago
Perfect Mikke. Looking…
Perfect Mikke.
Looking forward to this.
  • Wed, 07/09/2025 - 16:41
    Gurux.Serial.Android 2.0.13
  • Wed, 07/09/2025 - 12:07
    gurux.dlms.c 9.0.2507.0901
  • Sat, 07/05/2025 - 15:04
    Gurux.DLMS.Python 1.0.188
  • Tue, 07/01/2025 - 10:09
    Gurux.DLMS.Python 1.0.187
  • Tue, 07/01/2025 - 09:54
    gurux.dlms.c 9.0.2507.0101
  • Regarding the dlms android project
  • Unable to read attribute =3 (1.0.94.91.0.255) IC=7 for Indian Metering, while I'm able to read attribute 3 for other Profile generic class
  • Register Activation class (class_id = 9) attribute index 3 data is not visible
  • Load profile
  • DLMS Decryption Implementation Status and Clarification Needed
