  2. Write Object Data 3 Issue
Write Object data 3 issue
By xsmy, 11 May, 2024
Gurux.DLMS.AMI
issue 1:
When writing object Attr data, the data submitted on the page is inconsistent with the data in the input box. The submitted data is the old data before editing.
issue 2:
When the write operation is completed, the XML format Value will be stored in the DB, which will cause an exception the next time the Attr data is edited again.
issue 3:
Nothing happens after clicking the Save button of the Object Page, and the edited data is not saved.
xsmy
1 year 7 months ago
issue 2 img
issue 2 img
xsmy
1 year 7 months ago
issue 2
issue 2
1 year 7 months ago
Hi, You are right. We have…
You are right. We have broken the clock write. This is fixed and is now in tests. A new version will be released tomorrow where this has been fixed.
xsmy
1 year 7 months ago
Thanks for your reply,…
Thanks for your reply, looking forward to the next version
  • Tue, 12/02/2025 - 10:21
    gurux.dlms.c 9.0.2512.0201
  • Mon, 12/01/2025 - 13:55
    Gurux.DLMS.Python 1.0.193
  • Thu, 11/13/2025 - 15:23
    Gurux.DLMS.Python 1.0.192
  • Thu, 11/13/2025 - 14:55
    gurux.dlms.java 4.0.84
  • Wed, 10/29/2025 - 08:51
    gurux.dlms.c 9.0.2510.2901
  • DLMS Meter Gurux DLMS Director Properties
  • Using MAX3232 + FT232RL to Energy meter with GXDLMS Director
  • SNRM byte mening
