  2. Help To Connect To Inhemeter DTZ1513
Help to connect to Inhemeter DTZ1513
Profile picture for user oulahsensaid
By oulahsensaid, 9 February, 2024
Hi, Mr Kurumi.
I try to connect to Inhemeter meter, but I got this message:
ServiceError Initiate Error exception. Initiate IncompatibleConformance.
GXDLMSDirector 9.0.2302.2001
Log created 15:46:22
15:46:31 Initializing serial connection.
15:46:32 IEC Sending:/?!<CR><LF>
15:46:42 Failed to receive reply from the device in given time.
15:46:43 HDLC received: /IHM5\2Inhe Meter<CR><LF>
15:46:43 BaudRate is : 9600
15:46:43 Moving to mode E.
06 32 35 32 0D 0A
15:46:46 Send SNRM request.
7E A0 07 03 03 93 8C 11 7E
15:46:46
7E A0 20 03 03 73 F0 2E 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
15:46:46 Parsing UA reply succeeded.
15:46:46 Send AARQ request.
7E A0 44 03 03 10 65 94 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 92 4A 7E
15:46:47
7E A0 2D 03 03 30 E0 D5 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 06 04 04 0E 01 06 02 F7 43 7E
15:46:47 Disconnect request
15:46:52 Failed to receive reply from the device in given time.
Gurux.DLMS.GXDLMSConfirmedServiceError: ServiceError Initiate Error exception. Initiate IncompatibleConformance
à Gurux.DLMS.Internal.GXAPDU.ParsePDU2(GXDLMSSettings settings, GXICipher cipher, GXByteBuffer buff, GXDLMSTranslatorStructure xml)
à Gurux.DLMS.Internal.GXAPDU.ParsePDU(GXDLMSSettings settings, GXICipher cipher, GXByteBuffer buff, GXDLMSTranslatorStructure xml)
à Gurux.DLMS.GXDLMSClient.ParseAAREResponse(GXByteBuffer reply)
à GXDLMSDirector.GXDLMSCommunicator.ParseAAREResponse(GXByteBuffer data)
à GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force)
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
1 year 4 months ago
Hi, Try to remove…
Try to remove DeltaValueEncoding from the supported services tab. It's causing problems with some meters.
oulahsensaid
1 year 4 months ago
Thank you for your response…
Thank you for your response.
Problem solved, the server address was wrong.
Best regards.
1 year 4 months ago
Hi, Thank you for letting me…
Thank you for letting me know about this. I can say that this is the most common reason why communication fails.
  • Thu, 06/19/2025 - 09:33
    Gurux.DLMS.Python 1.0.185
  • Wed, 06/18/2025 - 15:11
    Gurux.DLMS.Python 1.0.184
  • Wed, 06/18/2025 - 10:05
    Gurux.DLMS.Python 1.0.183
  • Wed, 06/18/2025 - 09:06
    GXDLMSDirector 9.0.2506.1801
  • Wed, 06/18/2025 - 08:41
    Gurux.DLMS.Net 9.0.2506.1801
  • HLS GMAC L+G 570
  • Unable to read parameter values from Landis+Gyr E550 meter using GXDLMSDirector - NoAccess status
  • data.SetComplete(false); But all data recieved
  • Crash (endless loop)
  • Server is not able to download object list with maxPduSize 64 or 128 (or anything below 156-bytes PDU size)
