  2. Parse Row Data Which Is In Comment In Xml
Parse Row Data which is in comment in xml
By pravin_kumbhare, 13 February, 2024
Gurux.Net
<SourceAddress Value="1" />
<FrameType Value="52" />
<PDU>
<!-- Invocation Counter: 1252 -->
<!-- Decrypt data: C4 02 81 01 00 00 00 01 00 82 00 38 01 03 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0B 05 FF 0F 02 12 00 00 02 04 12 00 01 09 06 00 00 60 0F 05 FF 0F 02 12 00 00
<GetResponse>
<GetResponsewithDataBlock>
# Priority: High, ServiceClass: UnConfirmed, Invoke ID: 1
<InvokeIdAndPriority Value="81" />
<Result>
<LastBlock Value="01" />
<BlockNumber Value="00000001" />
<Result>
<RawData Value="0103020412000809060000010000FF0F02120000020412000109060000600B05FF0F02120000020412000109060000600F05FF0F02120000" />
</Result>
</Result>
</GetResponsewithDataBlock>
</GetResponse>
<glo_GetResponse Value="30000004E4528E5D05921427F59267F07DBD90A843870ACF2D959C83B4CFA7EFC01575F1AC1C2F9EFE3ACACF00BEABC2A4A9D6B5989395D1059AD0CBE2CF6BD634C2879F8804B87E3504BA6B4E3095330CC666C179" />
</PDU>
</HDLC>
pravin_kumbhare
2 years 2 months ago
Hi, here i am facing the…
here i am facing the problem with raw data parsing
Hi, You don't need to parse…
You don't need to parse it from the XML. It's updated to the attribute and you can get it there. Like reading the invocation counter shows.
https://github.com/Gurux/Gurux.DLMS.Net/blob/c3b4b26bbcc2f566e238288aa6…
pravin_kumbhare
then how can i get raw data
Hi, If you want to get the…
If you want to get the raw bytes, you can get the decrypted data from the data property before updateValue is called.
pravin_kumbhare
Sir, Thank you for you…
Sir,
Thank you for you valuable time, but the problem still exists.
I want data2 value from the PduToXml method, so what should i needto do to get the value
internal string PduToXml(GXDLMSTranslatorStructure xml,
GXByteBuffer value,
bool omitDeclaration,
bool omitNameSpace,
bool allowUnknownCommand,
GXDLMSTranslatorMessage msg)
if (msg != null && msg.InterfaceType == InterfaceType.PrimeDcWrapper)
if (GXPrimeDcHandlers.HandleNotification(value, null, xml))
return xml.ToString();
GXDLMSSettings settings = new GXDLMSSettings(true, InterfaceType.HDLC);
try
GXReplyData data = new GXReplyData();
byte cmd = value.GetUInt8();
if (msg != null)
msg.Command = (Command)cmd;
GetCiphering(settings, GXDLMS.IsCiphered(cmd));
if (settings != null && settings.Cipher != null)
((GXCiphering)settings.Cipher).TestMode = true;
settings.Standard = Standard;
string str;
int len;
byte[] tmp;
switch (cmd)
case (byte)Command.Aarq:
value.Position = 0;
settings.SourceSystemTitle = null;
GXAPDU.ParsePDU(settings, settings.Cipher, value, xml);
//Update new dedicated key.
if (settings.Cipher != null && settings.Cipher.DedicatedKey != null)
DedicatedKey = settings.Cipher.DedicatedKey;
if (msg != null)
msg.SystemTitle = settings.SourceSystemTitle;
msg.DedicatedKey = settings.Cipher.DedicatedKey;
break;
case (byte)Command.InitiateRequest:
value.Position = 0;
GXAPDU.ParseInitiate(true, settings, settings.Cipher, value,
xml);
break;
case (byte)Command.InitiateResponse:
value.Position = 0;
settings = new GXDLMSSettings(false, InterfaceType.HDLC);
GetCiphering(settings, true);
xml);
break;
case 0x81://Ua
if (msg != null)
msg.Command = Command.Ua;
value.Position = 0;
GetUa(value, xml);
break;
case (byte)Command.Aare:
value.Position = 0;
if (msg != null)
break;
case (byte)Command.GetRequest:
GXDLMSLNCommandHandler.HandleGetRequest(settings, null, value, null, xml, Command.None);
break;
case (byte)Command.SetRequest:
GXDLMSLNCommandHandler.HandleSetRequest(settings, null, value, null, xml, Command.None);
break;
case (byte)Command.ReadRequest:
GXDLMSSNCommandHandler.HandleReadRequest(settings, null, value, null, xml, Command.None);
break;
case (byte)Command.MethodRequest:
GXDLMSLNCommandHandler.HandleMethodRequest(settings, null, value, null, null, xml, Command.None);
break;
case (byte)Command.WriteRequest:
GXDLMSSNCommandHandler.HandleWriteRequest(settings, null, value, null, xml, Command.None);
break;
case (byte)Command.AccessRequest:
GXDLMSLNCommandHandler.HandleAccessRequest(settings, null, value, null, xml, Command.None);
break;
case (byte)Command.DataNotification:
data.Xml = xml;
data.Data = value;
value.Position = 0;
GXDLMS.GetPdu(settings, data);
break;
case (byte)Command.InformationReport:
data.Xml = xml;
data.Data = value;
GXDLMSSNCommandHandler.HandleInformationReport(settings, data, null);
break;
case (byte)Command.EventNotification:
data.Xml = xml;
data.Data = value;
GXDLMSLNCommandHandler.HandleEventNotification(settings, data, null);
break;
case (byte)Command.ReadResponse:
case (byte)Command.WriteResponse:
case (byte)Command.GetResponse:
case (byte)Command.SetResponse:
case (byte)Command.MethodResponse:
case (byte)Command.AccessResponse:
case (byte)Command.GeneralBlockTransfer:
data.Xml = xml;
data.Data = value;
value.Position = 0;
break;
case (byte)Command.GeneralCiphering:
data.Xml = xml;
data.Data = value;
value.Position = 0;
break;
case (byte)Command.ReleaseRequest:
xml.AppendStartTag((Command)cmd);
value.GetUInt8();
// Len.
if (value.Available != 0)
// BerType
value.GetUInt8();
// Len.
value.GetUInt8();
if (xml.OutputType == TranslatorOutputType.SimpleXml)
str = TranslatorSimpleTags.ReleaseRequestReasonToString((ReleaseRequestReason)value.GetUInt8());
else
str = TranslatorStandardTags.ReleaseRequestReasonToString((ReleaseRequestReason)value.GetUInt8());
xml.AppendLine(TranslatorTags.Reason, null, str);
int len2 = xml.GetXmlLength();
try
xml.AppendStartTag(TranslatorGeneralTags.UserInformation);
GXAPDU.ParsePDU2(settings, settings.Cipher, value,
xml);
xml.AppendEndTag(TranslatorGeneralTags.UserInformation);
catch (Exception)
//This usually fails if keys are wrong.
xml.SetXmlLength(len2);
xml.AppendEndTag(cmd);
break;
case (byte)Command.ReleaseResponse:
if (value.GetUInt8() != 0)
//BerType
value.GetUInt8();
//Len.
value.GetUInt8();
str = TranslatorSimpleTags.ReleaseResponseReasonToString((ReleaseResponseReason)value.GetUInt8());
else
str = TranslatorStandardTags.ReleaseResponseReasonToString((ReleaseResponseReason)value.GetUInt8());
xml.AppendLine(TranslatorTags.Reason, "Value", str);
GXAPDU.ParsePDU2(settings, settings.Cipher, value, xml);
xml.AppendEndTag((Command)cmd);
break;
case (byte)Command.GloReadRequest:
case (byte)Command.GloWriteRequest:
case (byte)Command.GloGetRequest:
case (byte)Command.GloSetRequest:
case (byte)Command.GloReadResponse:
case (byte)Command.GloWriteResponse:
case (byte)Command.GloGetResponse:
case (byte)Command.GloSetResponse:
case (byte)Command.GloMethodRequest:
case (byte)Command.GloMethodResponse:
case (byte)Command.DedGetRequest:
case (byte)Command.DedSetRequest:
case (byte)Command.DedReadResponse:
case (byte)Command.DedWriteResponse:
case (byte)Command.DedGetResponse:
case (byte)Command.DedSetResponse:
case (byte)Command.DedMethodRequest:
case (byte)Command.DedMethodResponse:
case (byte)Command.GloConfirmedServiceError:
case (byte)Command.DedConfirmedServiceError:
if (settings.Cipher != null && Comments)
int originalPosition = value.Position;
try
--value.Position;
Command c = (Command)cmd;
byte[] st;
if (c == Command.GloReadRequest || c == Command.GloWriteRequest || c == Command.GloGetRequest || c == Command.GloSetRequest || c == Command.GloMethodRequest ||
c == Command.DedGetRequest || c == Command.DedSetRequest || c == Command.DedMethodRequest)
st = settings.Cipher.SystemTitle;
else
st = settings.SourceSystemTitle;
if (st != null)
AesGcmParameter p;
if ((cmd == (byte)Command.DedGetRequest || cmd == (byte)Command.DedSetRequest ||
cmd == (byte)Command.DedReadResponse || cmd == (byte)Command.DedWriteResponse ||
cmd == (byte)Command.DedGetResponse || cmd == (byte)Command.DedSetResponse ||
cmd == (byte)Command.DedMethodRequest || cmd == (byte)Command.DedMethodResponse) &&
settings.Cipher.DedicatedKey != null && settings.Cipher.DedicatedKey.Length != 0)
p = new AesGcmParameter(settings, st, settings.Cipher.DedicatedKey, settings.Cipher.AuthenticationKey);
else
p = new AesGcmParameter(settings, st, settings.Cipher.BlockCipherKey, settings.Cipher.AuthenticationKey);
p.Xml = xml;
if (p.BlockCipherKey != null)
GXByteBuffer data2 = new GXByteBuffer(GXSecure.DecryptAesGcm(p, value));
xml.AppendComment("Invocation Counter: " + p.InvocationCounter.ToString());
xml.StartComment("Decrypt data: " + data2.ToString());
PduToXml(xml, data2, omitDeclaration, omitNameSpace, false, msg);
xml.EndComment();
catch (Exception)
// It's OK if this fails. Ciphering settings are not correct.
if (msg != null)
xml.AppendComment("Decrypt failed. Different block cipher or authentiocation key is used to generate this.");
value.Position = originalPosition;
break;
int cnt = GXCommon.GetObjectCount(value);
if (cnt != value.Size - value.Position)
xml.AppendComment("Invalid length: " + cnt + ". It should be: " + (value.Size - value.Position));
xml.AppendLine(cmd, "Value", GXCommon.ToHex(value.Data, false, value.Position, value.Size - value.Position));
break;
case (byte)Command.GeneralGloCiphering:
case (byte)Command.GeneralDedCiphering:
AesGcmParameter p = null;
--value.Position;
//Check is this client msg.
try
byte[] st;
if (cmd == (byte)Command.GeneralDedCiphering && settings.Cipher.DedicatedKey != null)
else
p.Xml = xml;
xml.EndComment();
catch (Exception)
--value.Position;
//Check is this server msg.
try
byte[] st;
if (st != null)
p.Xml = xml;
xml.EndComment();
catch (Exception)
if (msg != null)
len = GXCommon.GetObjectCount(value);
tmp = new byte[len];
value.Get(tmp);
xml.AppendLine(TranslatorTags.SystemTitle, null,
GXCommon.ToHex(tmp, false, 0, len));
value.Get(tmp);
xml.AppendLine(TranslatorTags.CipheredService, null,
break;
case (byte)Command.GeneralSigning:
--value.Position;
try
byte[] st;
p.Xml = xml;
xml.AppendComment("Security : " + p.Security);
xml.AppendComment("Security Suite: " + p.SecuritySuite);
xml.EndComment();
p.Xml.AppendLine(TranslatorTags.Content, null, GXCommon.ToHex(p.CipheredContent, false));
p.Xml.AppendLine(TranslatorTags.Signature, null, GXCommon.ToHex(p.Signature, false));
catch (Exception)
if (msg != null)
if (value.Position == originalPosition)
GXByteBuffer transactionId = new GXByteBuffer();
GXCommon.SetObjectCount(len, transactionId);
transactionId.Set(value, len);
xml.AppendLine(TranslatorTags.TransactionId, null, xml.IntegerToHex(transactionId.GetUInt64(1), 16, true));
value.Get(tmp);
xml.AppendLine(TranslatorTags.OriginatorSystemTitle, null, GXCommon.ToHex(tmp, false));
value.Get(tmp);
xml.AppendLine(TranslatorTags.RecipientSystemTitle, null, GXCommon.ToHex(tmp, false));
// Get date time.
value.Get(tmp);
xml.AppendLine(TranslatorTags.DateTime, null, GXCommon.ToHex(tmp, false));
// other-information
len = value.GetUInt8();
value.Get(tmp);
xml.AppendLine(TranslatorTags.OtherInformation, null, GXCommon.ToHex(tmp, false));
value.Get(tmp);
xml.AppendLine(TranslatorTags.Content, null, GXCommon.ToHex(tmp, false));
value.Get(tmp);
xml.AppendLine(TranslatorTags.Signature, null, GXCommon.ToHex(tmp, false));
break;
case (byte)Command.ConfirmedServiceError:
data.Xml = xml;
data.Data = value;
GXDLMS.HandleConfirmedServiceError(data);
break;
case (byte)Command.GatewayRequest:
case (byte)Command.GatewayResponse:
data.Xml = xml;
data.Data = value;
//Get Network ID.
byte id = value.GetUInt8();
//Get Physical device address.
value.Get(tmp);
xml.AppendLine(TranslatorTags.NetworkId, null, id.ToString());
xml.AppendLine(TranslatorTags.PhysicalDeviceAddress, null, GXCommon.ToHex(tmp, false, 0, len));
PduToXml(xml, new GXByteBuffer(value.Remaining()), omitDeclaration, omitNameSpace, allowUnknownCommand, msg);
break;
case (byte)Command.ExceptionResponse:
data.Xml = xml;
data.Data = value;
GXDLMS.HandleExceptionResponse(data);
break;
case (byte)Command.DiscoverRequest:
data.Xml = xml;
data.Data = value;
HandleDiscoverRequest(data);
break;
case (byte)Command.DiscoverReport:
data.Xml = xml;
data.Data = value;
HandleDiscoverResponse(settings, data);
break;
case (byte)Command.RegisterRequest:
data.Xml = xml;
data.Data = value;
HandleRegisterRequest(msg.InterfaceType, data);
break;
case (byte)Command.PingResponse:
data.Xml = xml;
data.Data = value;
break;
case (byte)Command.RepeatCallRequest:
data.Xml = xml;
data.Data = value;
break;
default:
if (!allowUnknownCommand)
throw new Exception("Invalid command.");
--value.Position;
xml.AppendLine("<Data=\"" + GXCommon.ToHex(value.Data, false, value.Position, value.Size - value.Position) + "\" />");
break;
if (OutputType == TranslatorOutputType.StandardXml)
StringBuilder sb = new StringBuilder();
if (!omitDeclaration)
sb.AppendLine("<?xml version=\"1.0\" encoding=\"utf-8\"?>");
if (!omitNameSpace)
if (cmd != (byte)Command.Aare && cmd != (byte)Command.Aarq)
sb.AppendLine(
"<x:xDLMS-APDU xmlns:x=\"http://www.dlms.com/COSEMpdu\">");
else
sb.AppendLine(
"<x:aCSE-APDU xmlns:x=\"http://www.dlms.com/COSEMpdu\">");
sb.Append(xml.ToString());
if (!omitNameSpace)
sb.AppendLine("</x:xDLMS-APDU>");
else
sb.AppendLine("</x:aCSE-APDU>");
return sb.ToString();
finally
((GXCiphering)settings.Cipher).TestMode = false;
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
