  2. Svr_run Does Not Provide Demand Register Processing
svr_run does not provide demand register processing
Profile picture for user batulzii
By batulzii, 12 February, 2024
i could not found demand register log and serialize/save (file) in the server samples. Need to write svr_demend()?
Please, advice.
2 years ago
Hi, You can find the demand…
You can find the demand register example from the here:
https://github.com/Gurux/GuruxDLMS.c/blob/fa855d2e82db1a7d27c419d09ed7a…
batulzii
2 years ago
Hello, Yes, I found this…
Yes, I found this sample useful. But i could not found how demand register updated and stored. Any scripts or svr_run processing on period?
2 years ago
Hi, The demand register is…
The demand register is not updated automatically because the status attribute is manufacturer-dependent. It's a shame because if this was defined in the DLMS standard, this could be updated automatically. Now you need to implement this by yourself.
  • Sun, 02/01/2026 - 19:47
    gurux.dlms.cpp 9.0.2602.0101
  • Tue, 01/20/2026 - 10:38
    gurux.dlms.java 4.0.89
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Landisgyr meter
  • GxDateTime always return DayOfWeek as FF
  • Python GXDLMSTranslator
