  3. Unable To Communicate With MQTT
Unable to communicate with MQTT
By icabrera, 27 August, 2020
Gurux.MQTT
I am working in a implementation of MQTT for a Smart Meter through LTE. I am not using the Gurux.bridge because my meter supports natively MQTT.
The meter is suscribed to a topic "meter", and also Gurux DLMS director is configured to use the same broker and topic.
When I click on connect in Gurux DLMS director, I received in the another side the following frames:
{"id":1,"sender":"72346f17-90e1-4a7e-aeb7-2104a0891c6e"}
{"id":2,"sender":"72346f17-90e1-4a7e-aeb7-2104a0891c6e","type":3}
Afterthat, Gurux DLMS director says: Invalid topic 'meter'.
In the received data I cannot see payload or data related field, so I am unable to process into the meter and generate an answer.
Any help will be appreciated.
Thanks.
5 years 7 months ago
There are differences because MQTT is not defined on the DLMS standard. Can you share what meter returns and we can check ho to handle this case.¨
  • Tue, 04/14/2026 - 11:47
    gurux.dlms.java 4.0.93
  • Mon, 04/13/2026 - 16:12
    gurux.dlms.java 4.0.92
  • Mon, 04/13/2026 - 11:39
    Gurux.DLMS.Net 9.0.2604.1301
  • Tue, 04/07/2026 - 17:17
    Gurux.DLMS.Python 1.0.197
  • Tue, 04/07/2026 - 15:03
    gurux.dlms.c 9.0.2604.0701
  • FRMR information field translation
  • Connect to EDMI metter
  • Meter rejects reading multiple objects, but it conformance says it supports it.
  • ISKRA ME372 CONNECTION BY DLMSDIRECTOR
  • sudhakrishnareddy
  • levet
  • 4faza
  • Phúc
  • TRƯỜNG
