By suri371994, 22 February, 2023 Forums DLMSDirector when I read the L1 Voltage in the GXDLMS Director, I wonder 2 times the read command packet was observed in Log File. Please mention the Comments below mention read command and Response from the Device. Note: In the Director, I was sent 1 time to Read the L1 Voltage. L1 voltage read:- 17:37:25 Read object type Register index: 3 TX: 7E A0 19 03 41 32 3A BD E6 E6 00 C0 01 C1 00 03 01 00 20 07 00 FF 03 00 5D 9A 7E 17:37:25 RX: 7E A0 16 41 03 52 DD AA E6 E7 00 C4 01 C1 00 02 02 0F 00 16 23 07 3E 7E 17:37:25 Read object type Register index: 2 TX: 7E A0 19 03 41 54 0A BB E6 E6 00 C0 01 C1 00 03 01 00 20 07 00 FF 02 00 85 83 7E 17:37:25 RX: 7E A0 15 41 03 74 24 CB E6 E7 00 C4 01 C1 00 17 46 A1 7A 00 EB A2 7E Hi, You are reading two… Hi, You are reading two objects from the meter. At first the scaler and unit first and then the actual value. BR, Mikko As per your reply consider… As per your reply consider 1st Request packet is Scaler Unit:- 7E //Start Frame A0 //Des.Address 19 //Length 03 //server address 41 //client address 32 //Instance Value 3A BD //header CRC E6 // Des. LSAP E6 //Source LSAP 00 // LLC Quality Reserved for Future. C0 01 C1 00 03 //OBIS Class Id 01 00 20 07 00 FF //( OBIS Code -- 1.0.32.07.0.255 ) 03 //Attribute Id 00 //Instance 5D 9A //CRC ( FCS-16 ) 7E //End Frame 2nd Request packet is the Actual value:- 7E //Start Frame A0 //Des.Address 19 //Length 03 //server address 41 //client address 54 //Instance Value 0A BB //header CRC E6 // Des. LSAP E6 //Source LSAP 00 // LLC Quality Reserved for Future. C0 01 C1 00 03 //OBIS Class Id 01 00 20 07 00 FF //( OBIS Code -- 1.0.32.07.0.255 ) 02 //Attribute Id 00 //Instance 85 83 //CRC ( FCS-16 ) 7E //End Frame If I try to read straightaway actual value, I will get any error? Note: I think Attribute Id will play key importance in the parameter reading, is it? (Scaler unit=3,Actual value=2) Please mention the Instance of each data packet's importance. ### Receive packet… ### Receive packet Description. //Scaler unit response. 7E //Start Frame A0 //Des.Address 16 41 03 52 DD AA E6 // Des. LSAP E7 //Source LSAP Response 00 // LLC Quality Reserved for Future. C4 01 C1 // 00 02 02 0F 00 16 23 07 3E //CRC ( FCS-16 ) 7E //End Frame //Actual value response. 7E //Start Frame A0 //Des.Address 15 41 03 74 24 CB E6 // Des. LSAP E7 //Source LSAP Response 00 // LLC Quality Reserved for Future. C4 01 C1 // 00 17 46 A1 7A 00 //Value received ( 20669.000V ) EB A2 ////CRC ( FCS-16 ) 7E //End Frame Also, describe unknow data packet details. Log in or register to post comments
7E //Start Frame
A0 //Des.Address
19 //Length
03 //server address
41 //client address
32 //Instance Value
3A BD //header CRC
E6 // Des. LSAP
E6 //Source LSAP
C0 01 C1
03 //Attribute Id
00 //Instance
7E //End Frame
7E //Start Frame
A0 //Des.Address
19 //Length
03 //server address
41 //client address
54 //Instance Value
0A BB //header CRC
E6 // Des. LSAP
E6 //Source LSAP
C0 01 C1
02 //Attribute Id
00 //Instance
7E //End Frame
### Receive packet…
7E //Start Frame
A0 //Des.Address
16 41 03 52 DD AA
E6 // Des. LSAP
C4 01 C1 //
7E //End Frame
7E //Start Frame
A0 //Des.Address
15 41 03 74 24 CB
E6 // Des. LSAP
C4 01 C1 //
00 17
7E //End Frame
