By mekam srilatha, 8 February, 2023 Forums DLMSDirector Can anyone help me reading SARAL secure meter . this is the log iam getting: 17:31:53 Initializing serial connection. 17:31:54 Send SNRM request. 7E A0 07 03 23 93 BF 32 7E 17:31:54 7E A0 1F 23 03 73 C0 D3 81 80 13 05 02 01 00 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 FD FE 7E 17:31:54 Parsing UA reply succeeded. 17:31:54 Send AARQ request. 7E A0 44 03 23 10 56 B7 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 41 42 43 44 30 30 30 31 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 50 C7 7E 17:31:59 Data send failed. Try to resend 1/3 17:31:59 7E A0 07 23 03 31 AF 94 7E 17:31:59 Disconnect request 17:31:59 7E A0 07 23 03 1F D3 5C 7E System.Exception: Frame is not fully received. at Gurux.DLMS.GXDLMSClient.ParseAAREResponse(GXByteBuffer reply) at GXDLMSDirector.GXDLMSCommunicator.ParseAAREResponse(GXByteBuffer data) at GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force) at GXDLMSDirector.GXDLMSDevice.InitializeConnection() at GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters) Hi, The meter is sending an… Hi, The meter is sending an invalid reply. Can you connect without authentication (Authentication = None)? I believe that your client's address is different than the meter expects. BR, Mikko Log in or register to post comments
