  • Gurux Club
  3. GXXmlReader not publicly accessible?
Profile picture for user tbvk
By tbvk, 27 January, 2023
Hi there,
I plan on using the load functionality of the GXAssociationLogical name to load the association view from the filesystem as an XML file but the load method takes in a GXXmlReader which I cann spawn an instance of - how can I go about doing so?
1 month 3 weeks ago
Hi, You can serialize the…
You can serialize the objects using GXDLMSObjectCollection.load -method. You need just read the association view and then call GXDLMSObjectCollection.save.
Check the client example. It doesn't what you need when you add -o argument.
-o output.xml
tbvk
1 month 3 weeks ago
Thank you for your assistance
Fri, 03/24/2023 - 14:22
gurux.dlms.c 20230324.1
Thu, 03/23/2023 - 11:01
GXDLMSDirector 9.0.2303.2301
Thu, 03/23/2023 - 09:10
Gurux.DLMS.Python 1.0.142
Wed, 03/22/2023 - 13:51
Gurux.DLMS.Net 9.0.2303.2201
Wed, 03/22/2023 - 10:15
gurux.dlms.c 20230322.1
Open bugs
Gurux.DLMS.AMI4
1
Gurux.DLMS.Android
1
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
