  • Gurux Club
  3. bug in dlms C?
bug in dlms C?
By labasvakaras, 5 January, 2023
Hello, tried your dlms.c library, wanted to ask if this is a bug or I am using library wrong?
String data is trash value although data in reply is good. Scrolled through your cosem metods and saw:
cosem_setGsmDiagnostic():
memcpy(object->operatorName, value->strVal, value->strVal->size);
should'nt it be
memcpy(object->operatorName, value->strVal->data, value->strVal->size);
made a patch myself and it works.
8 months 3 weeks ago
I believe that you are right and thank you for pointing this out. This is released after the tests are over. I hope it's today.
labasvakaras
also, I found bug with mac
also, I found bug with mac address (octet string), that it is not printed also. Trying to find where is the problem.
EDIT: probably there is no octetstring handling, because now bb_toString returns trash values, but bb_toHexString() returns something similar what it should be.
EDIT2:
wanted to ask why there is difference in obj_getAttributeIndexToRead():
DLMS_IGNORE_EXTENDED_REGISTER is if (!((gxExtendedRegister*)object)->unit == 0)
differs from other two registers types: if (!((gxDemandRegister*)object)->unitRead)
because i get error with extended register "invalid parameter". Is this expected?
labasvakaras
8 months 2 weeks ago
any updates on this issue?
any updates on issue about extended register?
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
  • azcah
  • Robertciz
  • Ilushikqtg
  • Margaretyhs
  • Mariohag
