  • Gurux Club
  3. Profile Generic
Profile Generic
Profile picture for user kevin jose minj
By kevin jose minj, 5 January, 2023
When I am reading the events it is not possible to read one by one objects it is throwing some invalid block number error.what is the issue?Here us the output
-------- Reading ObjectType.PROFILE_GENERIC 0.0.99.98.3.255 Ch. 0 Event log #4
Entries: 35/50
12/28/22 14:23:31 | 152
12/28/22 14:18:54 | 158
12/28/22 14:18:44 | 158
12/28/22 14:17:54 | 158
12/28/22 14:17:51 | 158
12/28/22 14:17:47 | 158
12/28/22 10:07:41 | 158
12/28/22 10:07:02 | 158
12/27/22 09:41:31 | 152
12/26/22 12:17:11 | 153
12/26/22 12:08:43 | 153
12/26/22 12:04:13 | 152
12/26/22 12:02:44 | 152
12/26/22 10:34:29 | 152
12/26/22 10:33:25 | 153
12/26/22 10:32:29 | 153
12/26/22 10:30:37 | 152
12/26/22 10:30:27 | 153
12/26/22 10:07:03 | 153
12/26/22 10:03:29 | 153
12/26/22 10:02:32 | 153
12/26/22 10:01:53 | 153
12/26/22 10:01:34 | 152
12/23/22 14:48:27 | 153
12/23/22 14:43:04 | 153
-------- Reading ObjectType.PROFILE_GENERIC 0.0.99.98.0.255 Ch. 0 Event log #1
Entries: 0/50
-------- Reading ObjectType.PROFILE_GENERIC 0.0.99.98.1.255 Ch. 0 Event log #2
Entries: 2/50
-------- Reading ObjectType.PROFILE_GENERIC 0.0.99.98.2.255 Ch. 0 Event log #3
Entries: 20/20
RX: 12:33:30 7E A0 3E 61 03 96 45 43 E6 E7 00 D4 30 30 00 00 00 13 2B 99 34 BB 65 9F EC 37 BA 6C 90 89 9E C7 39 DD 44 22 CD 2F 77 A0 A4 01 A7 3C 33 72 D9
92 E8 BB CF 1F CC B8 61 75 9B B9 96 71 10 F9 17 7E
Error! Failed to read last day: Invalid Block number. It is 4 and it should be 1.
-------- Reading ObjectType.PROFILE_GENERIC 0.0.99.98.4.255 Ch. 0 Event log #5
RX: 12:33:30 7E A0 2E 61 03 B8 98 48 E6 E7 00 D4 20 30 00 00 00 14 2C 7E A7 2F EA 4A E1 77 55 8B 58 32 DA 50 47 D9 DE 02 0F FB 68 50 10 6C D2 69 AE 3E 19
7E
Invalid Block number. It is 5 and it should be 1
8 months 3 weeks ago
There is an error with the meter. The block number should be set to one when rows are read and that is not done. You need to ask if there is a firmware update available for the meter where this is fixed.
kevin jose minj
How to read last 2 days value
How to read last 2 days value using python?which function I have to use?
8 months 2 weeks ago
You need to use readRowsByRange. Read this:
The example code is here:
https://github.com/Gurux/Gurux.DLMS.Python/blob/258a6f18233b83512f021b6…
Fri, 09/22/2023 - 19:50
gurux.dlms.c 20230922.1
Mon, 09/18/2023 - 13:51
Gurux.DLMS.AMI4 4.0.2309.1801
Fri, 09/15/2023 - 12:00
gurux.dlms.c 20230915.1
Tue, 09/12/2023 - 11:10
Gurux.DLMS.AMI4 4.0.2309.1201
Fri, 09/08/2023 - 10:59
gurux.dlms.c 20230908.1
Open bugs
gurux.dlms.c
3
gurux.dlms.cpp
3
gurux.dlms.delphi
1
  • problem with date and time in ION
  • Permament rejected
  • DLMS- GMAC: SNRM, AARQ, AARE is responding but not able to decrypt the Authentication key received from the meter
  • List complete policy security configuration basic (configuration security))
  • Save Association view in database
  • azcah
  • Robertciz
  • Ilushikqtg
  • Margaretyhs
  • Mariohag
